#include <pqDisplayPanelPropertyWidget.h>
| pqDisplayPanelPropertyWidget (pqDisplayPanel *displayPanel, QWidget *parent=nullptr) | |
| ~pqDisplayPanelPropertyWidget () override | |
| pqDisplayPanel * | getDisplayPanel () const |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Definition at line 12 of file pqDisplayPanelPropertyWidget.h.
explicit |
| pqDisplayPanel* pqDisplayPanelPropertyWidget::getDisplayPanel | ( | ) | const |
1.8.13 on Sun Dec 14 2025
