Public Member Functions | List of all members
pqDisplayRepresentationPropertyWidget Class Reference
A property widget for selecting the display representation. More...
#include <pqDisplayRepresentationWidget.h>
Inheritance diagram for pqDisplayRepresentationPropertyWidget:
Collaboration diagram for pqDisplayRepresentationPropertyWidget:
 pqDisplayRepresentationPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqDisplayRepresentationPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void setReadOnly (bool readOnly)
 Set widget in read-only mode. More...
virtual void select ()
virtual void deselect ()
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
Definition at line 79 of file pqDisplayRepresentationWidget.h.
◆ pqDisplayRepresentationPropertyWidget()
pqDisplayRepresentationPropertyWidget::pqDisplayRepresentationPropertyWidget ( vtkSMProxy proxy,
QWidget *  parent = nullptr
◆ ~pqDisplayRepresentationPropertyWidget()
pqDisplayRepresentationPropertyWidget::~pqDisplayRepresentationPropertyWidget ( )
override
