Public Member Functions | Protected Slots | List of all members
pqDoubleRangeSliderPropertyWidget Class Reference
pqDoubleRangeSliderPropertyWidget is a widget used for properties such as the "ThresholdRange" property on the IsoVolume filter's panel. More...
#include <pqDoubleRangeSliderPropertyWidget.h>
Inheritance diagram for pqDoubleRangeSliderPropertyWidget:
Collaboration diagram for pqDoubleRangeSliderPropertyWidget:
 pqDoubleRangeSliderPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqDoubleRangeSliderPropertyWidget () override
void apply () override
void reset () override
 ~pqPropertyWidget () override
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void setReadOnly (bool readOnly)
 Set widget in read-only mode. More...
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void highlightResetButton (bool highlight=true)
void resetClicked ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
It provides two double sliders, one for min and one for max and has logic to ensure that the min <= max.
The appearance of this widget can be modified by hints in the property XML definition. If a hint element named "HideResetButton" is present, the range reset button will be hidden. If a hint element named "MinimumLabel" is present with a "text" attribute, that text attribute will be used as the label text instead of "Minimum". Similarly, the default "Maximum" label can be replaced with a "MaximumLabel" element with a "text" attribute.
Definition at line 23 of file pqDoubleRangeSliderPropertyWidget.h.
◆ pqDoubleRangeSliderPropertyWidget()
pqDoubleRangeSliderPropertyWidget::pqDoubleRangeSliderPropertyWidget ( vtkSMProxy proxy,
vtkSMProperty property,
QWidget *  parent = nullptr
◆ ~pqDoubleRangeSliderPropertyWidget()
pqDoubleRangeSliderPropertyWidget::~pqDoubleRangeSliderPropertyWidget ( )
override
◆ apply()
void pqDoubleRangeSliderPropertyWidget::apply ( )
Reimplemented from pqPropertyWidget.
◆ reset()
void pqDoubleRangeSliderPropertyWidget::reset ( )
◆ highlightResetButton
void pqDoubleRangeSliderPropertyWidget::highlightResetButton ( bool  highlight = true)
protectedslot
◆ resetClicked
void pqDoubleRangeSliderPropertyWidget::resetClicked ( )
protectedslot
