Signals | Public Member Functions | Protected Slots | List of all members
pqFileNamePropertyWidget Class Reference
pqFileNamePropertyWidget is used for the "File Name" property on the Environment annotation filter. More...
#include <pqFileNamePropertyWidget.h>
Inheritance diagram for pqFileNamePropertyWidget:
Collaboration diagram for pqFileNamePropertyWidget:
Signals
void clearHighlight ()
 internal signal used to clear highlights from pqHighlightablePushButton. More...
void highlightResetButton ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqFileNamePropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqFileNamePropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void setReadOnly (bool readOnly)
 Set widget in read-only mode. More...
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
virtual void resetButtonClicked ()
 update the property's value using the domain. More...
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
It customizes the resetButtonClicked() logic since the Environment filter's filename setup is custom.
Definition at line 15 of file pqFileNamePropertyWidget.h.
◆ pqFileNamePropertyWidget()
pqFileNamePropertyWidget::pqFileNamePropertyWidget ( vtkSMProxy proxy,
vtkSMProperty property,
QWidget *  parent = nullptr
◆ ~pqFileNamePropertyWidget()
pqFileNamePropertyWidget::~pqFileNamePropertyWidget ( )
override
◆ clearHighlight
void pqFileNamePropertyWidget::clearHighlight ( )
signal
◆ highlightResetButton
void pqFileNamePropertyWidget::highlightResetButton ( )
signal
◆ resetButtonClicked
virtual void pqFileNamePropertyWidget::resetButtonClicked ( )
protectedvirtualslot
