pqGlyphScaleFactorPropertyWidget is used for the "Scale Factor" property on the Glyph filter. More...
#include <pqGlyphScaleFactorPropertyWidget.h>
| pqGlyphScaleFactorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
| ~pqGlyphScaleFactorPropertyWidget () override | |
Public Member Functions inherited from pqDoubleVectorPropertyWidget | |
| pqDoubleVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr) | |
| ~pqDoubleVectorPropertyWidget () override | |
| void | apply () override |
| void | reset () override |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
Protected Slots | |
| void | resetButtonClicked () override |
| update the property's value using the domain. More... | |
Protected Slots inherited from pqDoubleVectorPropertyWidget | |
| virtual void | resetButtonClicked () |
| called when the user clicks the "reset" button for a specific property. More... | |
| void | scaleHalf () |
| void | scaleTwice () |
| void | scale (double) |
| void | resetToActiveDataBounds () |
| sets the value using active source's data bounds. More... | |
| void | resetToBounds (const double bds[6]) |
| sets the value to the specified bounds. More... | |
Signals inherited from pqDoubleVectorPropertyWidget | |
| void | clearHighlight () |
| internal signal used to clear highlights from pqHighlightablePushButton. More... | |
| void | highlightResetButton () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
It customizes the resetButtonClicked() logic since the Glyph filter's scale factor setup is custom.
Definition at line 15 of file pqGlyphScaleFactorPropertyWidget.h.
| pqGlyphScaleFactorPropertyWidget::pqGlyphScaleFactorPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | property, | ||
overrideprotectedslot |
1.8.13 on Sun Dec 14 2025
