pqImageCompressorWidget is a pqPropertyWidget designed to be used for "CompressorConfig" property on "RenderView" or "RenderViewSettings" proxy. More...
#include <pqImageCompressorWidget.h>
Public Slots | |
| void | setCompressorConfig (const QString &) |
Signals | |
| void | compressorConfigChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqImageCompressorWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqImageCompressorWidget () override | |
| QString | compressorConfig () const |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
Properties | |
| QString | compressorConfig |
| template<class T > | |
It works with a string property that expects the config in a predetermined format (refer to the code for details on the format).
Definition at line 16 of file pqImageCompressorWidget.h.
| pqImageCompressorWidget::pqImageCompressorWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | smproperty, | ||
| QString pqImageCompressorWidget::compressorConfig | ( | ) | const |
slot |
signal |
readwrite |
Definition at line 20 of file pqImageCompressorWidget.h.
1.8.13 on Sun Dec 14 2025
