pqIndexSelectionWidget displays a list of labels and slider widgets, intended to be used for selecting an index into a zero-based enumeration.
#include <pqIndexSelectionWidget.h>
| bool | eventFilter (QObject *obj, QEvent *e) override |
| void | propertyChanged () |
| | Update the widget state from the PropertyLink Qt property. More...
Definition at line 22 of file pqIndexSelectionWidget.h.
◆ pqIndexSelectionWidget()
| pqIndexSelectionWidget::pqIndexSelectionWidget |
vtkSMProxy * |
proxy, |
vtkSMProperty * |
property, |
QWidget * |
parent = nullptr |
◆ ~pqIndexSelectionWidget()
| pqIndexSelectionWidget::~pqIndexSelectionWidget |
◆ setHeaderLabel
| void pqIndexSelectionWidget::setHeaderLabel |
const QString & |
str | ) |
slot |
◆ setPushPropertyName
| void pqIndexSelectionWidget::setPushPropertyName |
const QByteArray & |
pName | ) |
slot |
◆ widgetModified
| void pqIndexSelectionWidget::widgetModified |
signal |
◆ currentChanged [1/3]
| void pqIndexSelectionWidget::currentChanged |
const QString & |
current | ) |
protectedslot |
◆ currentChanged [2/3]
int |
current | ) |
protectedslot |
◆ currentChanged [3/3]
protectedslot |
◆ updateProperty
| void pqIndexSelectionWidget::updateProperty |
protectedslot |
Start a timer that calls updatePropertyImpl.
This slot is triggered when a widget is modified.
◆ updatePropertyImpl
| void pqIndexSelectionWidget::updatePropertyImpl |
protectedslot |
Update the Qt property with current widget state.
Emits widgetModified.
◆ eventFilter()
| bool pqIndexSelectionWidget::eventFilter |
QObject * |
obj, |
QEvent * |
e |
◆ propertyChanged()
| void pqIndexSelectionWidget::propertyChanged |
