widget for input property to choose a pipeline input. More...
#include <pqInputSelectorWidget.h>
Public Slots | |
| void | setSelectedInput (pqSMProxy) |
Signals | |
| void | selectedInputChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqInputSelectorWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqInputSelectorWidget () override | |
| pqSMProxy | selectedInput () const |
| Chosen port. More... | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
Properties | |
| pqSMProxy | selectedInput |
| template<class T > | |
Generally, pqProxyWidget does not show widget for input properties. This is by design since changing input to filters is generally not a thing we let the user treat at same level as changing other properties. In some cases, however, we may want to show a combo-box to let user pick the input from the available pipeline proxies. pqInputSelectorWidget is designed for such exceptional cases. To use this widget for a vtkSMInputProperty, set panel_widget attribute to input_selector.
Definition at line 29 of file pqInputSelectorWidget.h.
| pqInputSelectorWidget::pqInputSelectorWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | smproperty, | ||
| pqSMProxy pqInputSelectorWidget::selectedInput | ( | ) | const |
Chosen port.
This returns vtkSmartPointer<vtkSMOutputPort> for the chosen port. if any.
slot |
signal |
readwrite |
Definition at line 33 of file pqInputSelectorWidget.h.
1.8.13 on Sun Dec 14 2025
