pqIntMaskPropertyWidget is designed to be used for an IntVectorProperty that can have a value that is set by or-ing together flags. More...
#include <pqIntMaskPropertyWidget.h>
Public Slots | |
| void | setMask (int mask) |
| Set the mask. More... | |
Signals | |
| void | maskChanged () |
| Fired whenever the user changes the selection. More... | |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqIntMaskPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqIntMaskPropertyWidget () override | |
| int | mask () const |
| Returns the current mask value. More... | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
Properties | |
| int | mask |
| template<class T > | |
The user is presented with a button with menu from which they can select multiple items. The resulting property value is determined by or-ing together the flag values for each of the checked item.
The flag/mask labels and their values are specified as hints on the XML property. The following XML snippet demonstrates how to use this property widget.
Definition at line 41 of file pqIntMaskPropertyWidget.h.
| pqIntMaskPropertyWidget::pqIntMaskPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | smproperty, | ||
| int pqIntMaskPropertyWidget::mask | ( | ) | const |
slot |
Set the mask.
signal |
readwrite |
Definition at line 45 of file pqIntMaskPropertyWidget.h.
1.8.13 on Mon Dec 15 2025
