pqInteractiveProperty2DWidget is an abstract pqInteractivePropertyWidgetAbstract subclass designed to serve as the superclass for all pqInteractivePropertyWidgetAbstract types that have interactive widget (also called 2D Widgets) associated with them. More...
#include <pqInteractiveProperty2DWidget.h>
| pqInteractiveProperty2DWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| ~pqInteractiveProperty2DWidget () override | |
| vtkSMNew2DWidgetRepresentationProxy * | widgetProxy () const |
| Returns the proxy for the interactive 2D widget. More... | |
Public Member Functions inherited from pqInteractivePropertyWidgetAbstract | |
| pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| ~pqInteractivePropertyWidgetAbstract () override | |
| void | reset () override |
| Overridden to call this->render() to ensure that the widget is redrawn. More... | |
| void | setView (pqView *view) override |
| Overridden to show the widget proxy in the new view. More... | |
| bool | isWidgetVisible () const |
| Returns the interactive widget's visibility. More... | |
| vtkSMProxy * | dataSource () const |
| Returns the data source. More... | |
| vtkBoundingBox | dataBounds (bool visibleOnly=false) const |
| Returns bounds from the dataSource, if possible. More... | |
| vtkSMPropertyGroup * | propertyGroup () const |
| Returns the vtkSMPropertyGroup pass to the constructor. More... | |
| void | hideEvent (QHideEvent *) override |
| Overriden in order to hide the VTK widget. More... | |
| void | showEvent (QShowEvent *) override |
| Overriden in order to show the VTK widget. More... | |
| void | select () override |
| In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More... | |
| void | deselect () override |
| void | selectPort (int portIndex) final |
| virtual void | apply () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| vtkSMNewWidgetRepresentationProxyAbstract * | internalWidgetProxy () final |
| Get the internal instance of the widget proxy. More... | |
Protected Member Functions inherited from pqInteractivePropertyWidgetAbstract | |
| void | setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy) |
| Setup all the links and events for the given widget and SM property group. More... | |
| void | setupUserObserver (vtkSMProxy *smproxy) |
Public Slots inherited from pqInteractivePropertyWidgetAbstract | |
| virtual void | setWidgetVisible (bool val) |
| Toggle the interactive widget's visibility. More... | |
| void | setDataSource (vtkSMProxy *dataSource) |
| DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More... | |
Signals inherited from pqInteractivePropertyWidgetAbstract | |
| void | widgetVisibilityToggled (bool) |
| Fired whenever setWidgetVisible() changes the widget's visibility. More... | |
| void | widgetVisibilityUpdated (bool) |
| Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More... | |
| void | startInteraction () |
| Fired by the underlying interactive widget representation proxy, for each respective events. More... | |
| void | interaction () |
| void | endInteraction () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Protected Slots inherited from pqInteractivePropertyWidgetAbstract | |
| virtual void | placeWidget ()=0 |
| Places the interactive widget using current data source information. More... | |
| void | render () |
| Safe call render on the view. More... | |
| virtual void | updateWidgetVisibility () |
| This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More... | |
Protected Attributes inherited from pqInteractivePropertyWidgetAbstract | |
| bool | VisibleState = true |
| bool | WidgetVisibility = false |
| int | LinkedPortIndex = -1 |
Properties inherited from pqInteractivePropertyWidgetAbstract | |
| pqSMProxy | dataSource |
pqInteractiveProperty2DWidget is intended to provide a Qt widget (along with an interactive widget in the active view) for controlling properties on the proxy identified by a vtkSMPropertyGroup passed to the constructor. Subclasses are free to determine which interactive widget to create and how to setup the UI for it.
pqInteractiveProperty2DWidget is basically the same as pqInteractivePropertyWidget but use vtkSMNew2DWidgetRepresentationProxy instead vtkSMNewWidgetRepresentationProxy
Definition at line 31 of file pqInteractiveProperty2DWidget.h.
| pqInteractiveProperty2DWidget::pqInteractiveProperty2DWidget | ( | const char * | widget_smgroup, |
| const char * | widget_smname, | ||
| vtkSMProxy * | proxy, | ||
| vtkSMPropertyGroup * | smgroup, | ||
Definition at line 45 of file pqInteractiveProperty2DWidget.h.
inlinefinalprotectedvirtual |
Implements pqInteractivePropertyWidgetAbstract.
Definition at line 51 of file pqInteractiveProperty2DWidget.h.
1.8.13 on Mon Dec 15 2025
