pqMultiComponentsDecorator's purpose is to prevent the GUI from showing Multi Components Mapping checkbox when the representation is not Volume, the number of components is not valid or MapScalars is not checked. More...
#include <pqMultiComponentsDecorator.h>
| pqMultiComponentsDecorator (vtkPVXMLElement *config, pqPropertyWidget *parentObject) | |
| ~pqMultiComponentsDecorator () override=default | |
| bool | canShowWidget (bool show_advanced) const override |
| Overridden to hide the widget. More... | |
Public Member Functions inherited from pqPropertyWidgetDecorator | |
| pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent) | |
| Constructor. More... | |
| ~pqPropertyWidgetDecorator () override | |
| pqPropertyWidget * | parentWidget () const |
| Returns the pqPropertyWidget parent. More... | |
| virtual bool | enableWidget () const |
| Override this method to override the enable state of the widget in the panel. More... | |
Signals inherited from pqPropertyWidgetDecorator | |
| void | visibilityChanged () |
| This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
| void | enableStateChanged () |
Static Public Member Functions inherited from pqPropertyWidgetDecorator | |
| static pqPropertyWidgetDecorator * | create (vtkPVXMLElement *xml, pqPropertyWidget *parent) |
| Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More... | |
Protected Member Functions inherited from pqPropertyWidgetDecorator | |
| vtkPVXMLElement * | xml () const |
Definition at line 17 of file pqMultiComponentsDecorator.h.
| pqMultiComponentsDecorator::pqMultiComponentsDecorator | ( | vtkPVXMLElement * | config, |
| pqPropertyWidget * | parentObject | ||
overridedefault |
Reimplemented from pqPropertyWidgetDecorator.
1.8.13 on Sun Dec 14 2025
