pqOpenVRHidingDecorator's purpose is to prevent the GUI from showing any of the OpenVR specific rendering controls when Paraview is not configured with PARAVIEW_USE_OpenVR More...
#include <pqOpenVRHidingDecorator.h>
| pqOpenVRHidingDecorator (vtkPVXMLElement *config, pqPropertyWidget *parentObject) | |
| ~pqOpenVRHidingDecorator () override | |
| bool | canShowWidget (bool show_advanced) const override |
| Overridden to hide the widget when OpenVR is not compiled in. More... | |
Public Member Functions inherited from pqPropertyWidgetDecorator | |
| pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent) | |
| Constructor. More... | |
| ~pqPropertyWidgetDecorator () override | |
| pqPropertyWidget * | parentWidget () const |
| Returns the pqPropertyWidget parent. More... | |
| virtual bool | enableWidget () const |
| Override this method to override the enable state of the widget in the panel. More... | |
Signals inherited from pqPropertyWidgetDecorator | |
| void | visibilityChanged () |
| This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
| void | enableStateChanged () |
Static Public Member Functions inherited from pqPropertyWidgetDecorator | |
| static pqPropertyWidgetDecorator * | create (vtkPVXMLElement *xml, pqPropertyWidget *parent) |
| Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More... | |
Protected Member Functions inherited from pqPropertyWidgetDecorator | |
| vtkPVXMLElement * | xml () const |
Definition at line 12 of file pqOpenVRHidingDecorator.h.
| pqOpenVRHidingDecorator::pqOpenVRHidingDecorator | ( | vtkPVXMLElement * | config, |
| pqPropertyWidget * | parentObject | ||
Reimplemented from pqPropertyWidgetDecorator.
1.8.13 on Sun Dec 14 2025
