Signals | Public Member Functions | Protected Slots | Protected Member Functions | Friends | List of all members
pqPipelineSource Class Reference
PQ representation for a vtkSMProxy that can be involved in a pipeline. More...
#include <pqPipelineSource.h>
Inheritance diagram for pqPipelineSource:
Collaboration diagram for pqPipelineSource:
Signals
void connectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
 fired when a connection is created between two pqPipelineSources. More...
void preConnectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
void connectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
 fired when a connection is broken between two pqPipelineSources. More...
void preConnectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
void representationAdded (pqPipelineSource *source, pqDataRepresentation *repr, int srcOutputPort)
 fired when a representation is added. More...
void representationRemoved (pqPipelineSource *source, pqDataRepresentation *repr, int srcOutputPort)
 fired when a representation is removed. More...
void visibilityChanged (pqPipelineSource *source, pqDataRepresentation *repr)
 Fired when the visbility of a representation for the source changes. More...
void dataUpdated (pqPipelineSource *source)
 Fired right after the underlying algorithm updates (executes). More...
void selectionChanged (pqOutputPort *port)
 Fired when the selection on a port has changed. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
 pqPipelineSource (const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqPipelineSource () override
int getNumberOfOutputPorts () const
 A source may have multiple output ports. More...
pqOutputPortgetOutputPort (int outputport) const
 Returns the pqOutputPort for the given output port. More...
pqOutputPortgetOutputPort (const QString &portName) const
 Returns the pqOutputPort given the name of the port. More...
QList< pqOutputPort * > getOutputPorts () const
 Returns all the output ports. More...
int getNumberOfConsumers (int outputport) const
 Returns the number of consumers connected to the given output port. More...
int getNumberOfConsumers () const
 Get the number of consumers connected to output port 0. More...
pqPipelineSourcegetConsumer (int outputport, int index) const
 Get the consumer at a particulat index on a given output port. More...
pqPipelineSourcegetConsumer (int index) const
 Get consumer at a particular index on output port 0. More...
QList< pqPipelineSource * > getAllConsumers () const
 Returns a list of consumers for all output ports. More...
QList< pqDataRepresentation * > getRepresentations (int outputport, pqView *view) const
 Returns a list of representations for this source in the given view. More...
QList< pqDataRepresentation * > getRepresentations (pqView *view) const
pqDataRepresentationgetRepresentation (int outputport, pqView *view) const
 Returns the first representation for this source in the given view. More...
pqDataRepresentationgetRepresentation (pqView *view) const
QList< pqView * > getViews () const
 Returns a list of render modules in which this source has representations added (the representations may not be visible). More...
void renderAllViews (bool force=false)
 This method updates all render modules to which all representations for this source belong, if force is true, it for an immediate render otherwise render on idle. More...
void updatePipeline ()
 Update the pipeline with the current time. More...
vtkSMSourceProxygetSourceProxy ()
 Return the vtkSMSourceProxy instance corresponding to this pqPipelineSource. More...
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServergetServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxygetProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElementgetHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManagerproxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
Protected Slots
void onRepresentationVisibilityChanged ()
 Called when the visibility of any representation for this source changes. More...
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
void removeConsumer (int outputport, pqPipelineSource *)
 called by pqPipelineFilter when the connections change. More...
void addConsumer (int outputport, pqPipelineSource *)
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void initialize ()
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnectgetConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
Friends
class pqPipelineFilter
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
- Static Public Member Functions inherited from pqProxy
static pqProxyfindProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static std::string rstToHtml (const char *rstStr)
 convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
static QString rstToHtml (const QString &rstStr)
i.e that can have input and/or output. The public API is to observe the object, changes to the pipeline structure are only through protected function. These changes happen automatically as a reflection of the SM state.
Definition at line 32 of file pqPipelineSource.h.
◆ pqPipelineSource()
pqPipelineSource::pqPipelineSource ( const QString &  name,
vtkSMProxy proxy,
pqServer server,
QObject *  parent = nullptr
◆ ~pqPipelineSource()
pqPipelineSource::~pqPipelineSource ( )
override
◆ getNumberOfOutputPorts()
int pqPipelineSource::getNumberOfOutputPorts ( ) const
This method returns the number of output ports supported by this source.
◆ getOutputPort() [1/2]
pqOutputPort* pqPipelineSource::getOutputPort ( int  outputport) const
◆ getOutputPort() [2/2]
pqOutputPort* pqPipelineSource::getOutputPort ( const QString &  portName) const
◆ getOutputPorts()
QList<pqOutputPort*> pqPipelineSource::getOutputPorts ( ) const
◆ getNumberOfConsumers() [1/2]
int pqPipelineSource::getNumberOfConsumers ( int  outputport) const
◆ getNumberOfConsumers() [2/2]
int pqPipelineSource::getNumberOfConsumers ( ) const
inline
Equivalent to calling getNumberOfConsumers(0);
Definition at line 72 of file pqPipelineSource.h.
◆ getConsumer() [1/2]
pqPipelineSource* pqPipelineSource::getConsumer ( int  outputport,
int  index
) const
◆ getConsumer() [2/2]
pqPipelineSource* pqPipelineSource::getConsumer ( int  index) const
inline
Equivalent to calling getConsumer(0, index);
Definition at line 83 of file pqPipelineSource.h.
◆ getAllConsumers()
QList<pqPipelineSource*> pqPipelineSource::getAllConsumers ( ) const
◆ getRepresentations() [1/2]
QList<pqDataRepresentation*> pqPipelineSource::getRepresentations ( int  outputport,
pqView view
) const
If view == nullptr, returns all representations of this source.
◆ getRepresentations() [2/2]
QList<pqDataRepresentation*> pqPipelineSource::getRepresentations ( pqView view) const
inline
Definition at line 95 of file pqPipelineSource.h.
◆ getRepresentation() [1/2]
pqDataRepresentation* pqPipelineSource::getRepresentation ( int  outputport,
pqView view
) const
If view is nullptr, returns 0.
◆ getRepresentation() [2/2]
pqDataRepresentation* pqPipelineSource::getRepresentation ( pqView view) const
inline
Definition at line 105 of file pqPipelineSource.h.
◆ getViews()
QList<pqView*> pqPipelineSource::getViews ( ) const
◆ renderAllViews()
void pqPipelineSource::renderAllViews ( bool  force = false)
◆ updatePipeline()
void pqPipelineSource::updatePipeline ( )
◆ getSourceProxy()
vtkSMSourceProxy* pqPipelineSource::getSourceProxy ( )
◆ connectionAdded
void pqPipelineSource::connectionAdded ( pqPipelineSource source,
pqPipelineSource consumer,
int  srcOutputPort
signal
◆ preConnectionAdded
void pqPipelineSource::preConnectionAdded ( pqPipelineSource source,
int  srcOutputPort
signal
◆ connectionRemoved
void pqPipelineSource::connectionRemoved ( pqPipelineSource source,
int  srcOutputPort
signal
◆ preConnectionRemoved
void pqPipelineSource::preConnectionRemoved ( pqPipelineSource source,
int  srcOutputPort
signal
◆ representationAdded
void pqPipelineSource::representationAdded ( pqPipelineSource source,
pqDataRepresentation repr,
int  srcOutputPort
signal
◆ representationRemoved
void pqPipelineSource::representationRemoved ( pqPipelineSource source,
int  srcOutputPort
signal
◆ visibilityChanged
void pqPipelineSource::visibilityChanged ( pqPipelineSource source,
signal
Also fired when representationAdded or representationRemoved is fired since that too implies change in source visibility.
◆ dataUpdated
void pqPipelineSource::dataUpdated ( pqPipelineSource source)
signal
This can be used to update data information and other similar tasks.
◆ selectionChanged
void pqPipelineSource::selectionChanged ( pqOutputPort port)
signal
◆ onRepresentationVisibilityChanged
void pqPipelineSource::onRepresentationVisibilityChanged ( )
protectedslot
◆ removeConsumer()
void pqPipelineSource::removeConsumer ( int  outputport,
pqPipelineSource
◆ addConsumer()
void pqPipelineSource::addConsumer ( int  outputport,
pqPipelineSource
◆ pqPipelineFilter
friend class pqPipelineFilter
friend
Definition at line 201 of file pqPipelineSource.h.
