pqPropertyGroupWidget is a (custom) widget created for a PropertyGroup.
#include <pqPropertyGroupWidget.h>
| pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr) |
vtkSMPropertyGroup * | propertyGroup () const |
void | addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1) |
void | addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1) |
void | addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1) |
char * | panelVisibility () const override |
| Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
void | setPanelVisibility (const char *vis) override |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) |
| ~pqPropertyWidget () override |
virtual void | apply () |
virtual void | reset () |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual bool | isSingleRowItem () const |
| Determines if the PropertyWidget must be constructed using a single row. More...
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
| Provides access to the decorators for this widget. More...
virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More...
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
| These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More...
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
virtual void | setView (pqView *) |
| called to set the active view. More...
void | viewChanged (pqView *view) |
| This signal is emitted when the current view changes. More...
void | changeAvailable () |
| This signal is fired as soon as the user starts editing in the widget. More...
void | changeFinished () |
| This signal is fired as soon as the user is done with making an atomic change. More...
void | restartRequired () |
| Indicates that a restart of the program is required for the setting to take effect. More...
template<class T > |
static QString | getXMLName (T *object) |
| Description: This static utility method returns the XML name for an object as a QString. More...
static QString | getTooltip (vtkSMProperty *property) |
| Returns the tooltip to use for the property. More...
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
| Helper method to return value from WidgetHeight XML hint, if any. More...
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
| Parse a XML element as a list of label to use for this widget. More...
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
| For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More...
void | addDecorator (pqPropertyWidgetDecorator *) |
| Register a decorator. More...
void | removeDecorator (pqPropertyWidgetDecorator *) |
| Unregisters a decorator. More...
pqPropertyLinks & | links () |
| Provides access to the pqPropertyLinks instance. More...
It provides functions for linking standard controls with Server Manager properties as well as storing the property group.
- See also
- vtkSMPropertyGroup
Definition at line 29 of file pqPropertyGroupWidget.h.
◆ pqPropertyGroupWidget()
◆ propertyGroup()
◆ addPropertyLink() [1/9]
void pqPropertyGroupWidget::addPropertyLink |
QComboBox * |
cb, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [2/9]
QLineEdit * |
edit, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [3/9]
QCheckBox * |
button, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [4/9]
QToolButton * |
button, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [5/9]
QGroupBox * |
groupBox, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [6/9]
QDoubleSpinBox * |
spinBox, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [7/9]
QSpinBox * |
spinBox, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [8/9]
◆ addPropertyLink() [9/9]
◆ panelVisibility()
char* pqPropertyGroupWidget::panelVisibility |
const |
◆ setPanelVisibility()
void pqPropertyGroupWidget::setPanelVisibility |
const char * |
vis | ) |
