Property widget that can be used to edit a proxy set as the value of a ProxyProperty in a pop-up dialog. More...
#include <pqProxyEditorPropertyWidget.h>
Public Slots | |
| void | setProxyToEdit (pqSMProxy) |
Signals | |
| void | dummySignal () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqProxyEditorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqProxyEditorPropertyWidget () override | |
| pqSMProxy | proxyToEdit () const |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
Protected Slots | |
| void | buttonClicked () |
Properties | |
| pqSMProxy | proxyToEdit |
| template<class T > | |
e.g. RenderView proxy has a "GridActor3D" ProxyProperty which is set to a "GridActor3D" proxy. Using this widget allows the users to edit the properties on this GridActor3D, when present.
To use this widget, add 'panel_widget="proxy_editor"' to the property's XML.
Since it's common to have a property on the proxy being edited in the popup dialog which controls its visibility (or enabled state), we add support for putting that property as a checkbox in this pqProxyEditorPropertyWidget itself. For that, one can use ProxyEditorPropertyWidget hints.
Example XML:
Definition at line 40 of file pqProxyEditorPropertyWidget.h.
| pqProxyEditorPropertyWidget::pqProxyEditorPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | smproperty, | ||
| pqSMProxy pqProxyEditorPropertyWidget::proxyToEdit | ( | ) | const |
slot |
protectedslot |
signal |
readwrite |
Definition at line 44 of file pqProxyEditorPropertyWidget.h.
1.8.13 on Sun Dec 14 2025
