Encapsulates the multitab python editor. More...
#include <pqPythonTabWidget.h>
Inherits QTabWidget.
Public Slots | |
| void | createNewEmptyTab () |
| Add a new empty text area. More... | |
| void | addNewTextArea (const QString &filename, vtkTypeUInt32 location=0x10) |
| Loads the content of the file into the current tab if it's empty and not linked to another QText. More... | |
| void | closeCurrentTab () |
| Request to close the current tab. More... | |
Signals | |
| void | fileOpened (const QString &) |
| Raised when a file has been opened and loaded into the text edit widget. More... | |
| void | fileSaved (const QString &) |
| Raised when a file has been saved successfuly. More... | |
| pqPythonTabWidget (QWidget *parent) | |
| pqPythonTextArea * | getCurrentTextArea () const |
| Returns the current displayed pqPythonTextArea. More... | |
| void | connectActions (pqPythonEditorActions &actions) |
| Connects this class to the actions. More... | |
| void | updateActions (pqPythonEditorActions &actions) |
| Connects the current pqPythonTextArea to the actions. More... | |
| bool | saveOnClose () |
| Returns true if all opened buffer were saved on the disk. More... | |
| void | updateTrace (const QString &str) |
| Update the text in the paraview trace tab. More... | |
| void | stopTrace (const QString &str) |
| Update the text in the paraview python trace tab and converts it into a unamed script. More... | |
| template<typename T > | |
| void | linkTo (T *) |
| Link the input QTextEdit to one of the tab of the editor. More... | |
| void | loadFile (const QString &filename) |
| void | keyPressEvent (QKeyEvent *keyEvent) override |
| void | mousePressEvent (QMouseEvent *mouseEvent) override |
Provides a QWidget with multiple QTextArea to edit python scripts in paraview. The widget handles automatic saving, syntax highlighting and undo/redo features within each tab.
Definition at line 28 of file pqPythonTabWidget.h.
| pqPythonTabWidget::pqPythonTabWidget | ( | QWidget * | parent | ) |
Default constructor.
| [in] | parent | the QWidget owning this widget |
| pqPythonTextArea* pqPythonTabWidget::getCurrentTextArea | ( | ) | const |
| void pqPythonTabWidget::connectActions | ( | pqPythonEditorActions & | actions | ) |
| void pqPythonTabWidget::updateActions | ( | pqPythonEditorActions & | actions | ) |
| bool pqPythonTabWidget::saveOnClose | ( | ) |
| void pqPythonTabWidget::updateTrace | ( | const QString & | str | ) |
Creates a new one if the tab doesn't exist.
| void pqPythonTabWidget::stopTrace | ( | const QString & | str | ) |
If no tab exists, creates a new one.
If this objects is already linked within the editor, switch to that tab otherwise creates a new one
Definition at line 82 of file pqPythonTabWidget.h.
| void pqPythonTabWidget::loadFile | ( | const QString & | filename | ) |
slot |
slot |
Otherwise adds a new tab.
slot |
signal |
signal |
1.8.13 on Sun Dec 14 2025
