manages recent files menu used in ParaView. More...
#include <pqRecentFilesMenu.h>
Inherits QObject.
| pqRecentFilesMenu (QMenu &menu, QObject *p=nullptr) | |
| Assigns the menu that will display the list of files. More... | |
| ~pqRecentFilesMenu () override | |
| virtual bool | open (pqServer *server, const pqServerResource &resource) const |
| Open a resource on the given server. More... | |
| void | setSortByServers (bool val) |
| When set to true (default), the menu is arranged to keep resources that use the same server together. More... | |
| bool | sortByServers () const |
pqRecentFilesMenu manages the recent files (states, etc.) menu used in ParaView. pqRecentFilesMenu uses implementations of pqRecentlyUsedResourceLoaderInterface to handle how to show (icon, label) a recent item and how to handle user requesting to load that item.
To add support for different types of recent items in your custom application, you may want to provide new implementations for pqRecentlyUsedResourceLoaderInterface.
Definition at line 35 of file pqRecentFilesMenu.h.
| pqRecentFilesMenu::pqRecentFilesMenu | ( | QMenu & | menu, |
| QObject * | p = nullptr |
This also results in the menu have separators for the server names. Set to false if your application does not support connecting/disconnecting from server or you don't case about sorting the menu by servers.
Definition at line 58 of file pqRecentFilesMenu.h.
Definition at line 59 of file pqRecentFilesMenu.h.
1.8.13 on Sat Dec 13 2025
