pqReloadFilesReaction Class Reference
pqReloadFilesReaction adds handler code to reload the active reader or all readers depending on the ReloadMode passed in the constructor. More...
#include <pqReloadFilesReaction.h>
Inheritance diagram for pqReloadFilesReaction:
Collaboration diagram for pqReloadFilesReaction:
enum  ReloadModes { ActiveSource, AllSources }
 pqReloadFilesReaction (QAction *parent=nullptr, ReloadModes reloadMode=ActiveSource)
 ~pqReloadFilesReaction () override
bool reloadSources ()
 reload the active source or all sources if they support reload. More...
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 Constructor. More...
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static bool reload ()
 reload the active proxy if it supports reload. More...
static bool reload (vtkSMSourceProxy *proxy)
 reload the proxy if it supports reload. More...
void onTriggered () override
 Called when the action is triggered. More...
void updateEnableState () override
- Protected Slots inherited from pqReaction
virtual void updateMasterEnableState (bool)
- Protected Attributes inherited from pqReaction
bool IsMaster
It calls the "reload" property, identified by hints, if present, or calls vtkSMProxy::RecreateVTKObjects().
Definition at line 19 of file pqReloadFilesReaction.h.
◆ ReloadModes
Enumerator
ActiveSource
AllSources
Definition at line 25 of file pqReloadFilesReaction.h.
◆ pqReloadFilesReaction()
pqReloadFilesReaction::pqReloadFilesReaction ( QAction *  parent = nullptr,
ReloadModes  reloadMode = ActiveSource
◆ ~pqReloadFilesReaction()
pqReloadFilesReaction::~pqReloadFilesReaction ( )
override
◆ reload() [1/2]
static bool pqReloadFilesReaction::reload ( )
Returns true on success.
◆ reloadSources()
bool pqReloadFilesReaction::reloadSources ( )
◆ reload() [2/2]
static bool pqReloadFilesReaction::reload ( vtkSMSourceProxy proxy)
◆ onTriggered()
void pqReloadFilesReaction::onTriggered ( )
inlineoverrideprotectedvirtual
Definition at line 51 of file pqReloadFilesReaction.h.
◆ updateEnableState()
void pqReloadFilesReaction::updateEnableState ( )
