pqScalarBarRepresentation is created for "ScalarBarWidgetRepresentation" proxies. More...
#include <pqScalarBarRepresentation.h>
| pqScalarBarRepresentation (const QString &group, const QString &name, vtkSMProxy *scalarbar, pqServer *server, QObject *parent=nullptr) | |
| ~pqScalarBarRepresentation () override | |
Public Member Functions inherited from pqRepresentation | |
| pqRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=nullptr) | |
| ~pqRepresentation () override | |
| virtual bool | isVisible () const |
| Returns if the status of the visbility property of this display. More... | |
| virtual void | setVisible (bool visible) |
| Set the visibility. More... | |
| pqView * | getView () const |
| Returns the view to which this representation has been added, if any. More... | |
| vtkSMViewProxy * | getViewProxy () const |
| Returns the view proxy to which this representation has been added, if any. More... | |
Public Member Functions inherited from pqProxy | |
| pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
| ~pqProxy () override | |
| Get the server on which this proxy exists. More... | |
| This is a convenience method. More... | |
| Get the name with which this proxy is registered on the server manager. More... | |
| Get the vtkSMProxy this object stands for. More... | |
| Gets whether or not the source has been modified. More... | |
| Sets whether or not the source has been modified. More... | |
| Returns the hints for this proxy, if any. More... | |
| Returns a list of all helper proxies. More... | |
| Returns a list of all the helper proxies added with a given key. More... | |
| Returns the keys for helper proxies. More... | |
| Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
| Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
| Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
| Return whether or not the user has modified the GUI name of the source. More... | |
Public Member Functions inherited from pqServerManagerModelItem | |
| pqServerManagerModelItem (QObject *parent=nullptr) | |
| ~pqServerManagerModelItem () override | |
Protected Slots | |
| void | startInteraction () |
| void | endInteraction () |
Protected Slots inherited from pqRepresentation | |
| virtual void | onVisibilityChanged () |
| called when the display visibility property changes. More... | |
Protected Slots inherited from pqProxy | |
| void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
| void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
Public Types inherited from pqProxy | |
| enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
| The modification state of this proxy. More... | |
Public Slots inherited from pqRepresentation | |
| void | renderView (bool force) |
| Renders the view to which this representation has been added if any. More... | |
| void | renderViewEventually () |
| Simply calls renderView(false);. More... | |
Signals inherited from pqRepresentation | |
| void | visibilityChanged (bool visible) |
| Fired when the visibility property of the underlying display changes. More... | |
| void | updated () |
| Fired whenever Update() is called on the underlying display proxy. More... | |
Signals inherited from pqProxy | |
| void | nameChanged (pqServerManagerModelItem *) |
| Fired when the name of the proxy is changed. More... | |
| void | modifiedStateChanged (pqServerManagerModelItem *) |
| Fired when the modified status changes for the proxy. More... | |
Static Public Member Functions inherited from pqProxy | |
| static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
| Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
| static pqProxy * | findProxy (vtkSMProxy *aproxy) |
| Returns a pqProxy found under current pqServer and matching given vtkSMProxy. More... | |
Protected Member Functions inherited from pqRepresentation | |
| Called by pqView when this representation gets added to / removed from the view. More... | |
Protected Member Functions inherited from pqProxy | |
| Make this pqProxy take on a new identity. More... | |
| virtual void | initialize () |
Protected Member Functions inherited from pqServerManagerModelItem | |
| All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
The only reason why pqScalarBarRepresentation is used is to keep create undo elements to aid with undo/redo for scalar bar interaction i.e. if user drags the scalar-bar widget, we capture the entire operation in a single undo-able action.
Definition at line 20 of file pqScalarBarRepresentation.h.
| pqScalarBarRepresentation::pqScalarBarRepresentation | ( | const QString & | group, |
| const QString & | name, | ||
| vtkSMProxy * | scalarbar, | ||
| pqServer * | server, | ||
| QObject * | parent = nullptr |
protectedslot |
protectedslot |
1.8.13 on Sun Dec 14 2025
