#include <pqTextureSelectorPropertyWidget.h>
| pqTextureSelectorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
| ~pqTextureSelectorPropertyWidget () override=default | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
Protected Slots | |
| void | onTextureChanged (vtkSMProxy *texture) |
| void | onPropertyChanged () |
| void | checkAttributes (bool tcoords, bool tangents) |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Definition at line 22 of file pqTextureSelectorPropertyWidget.h.
| pqTextureSelectorPropertyWidget::pqTextureSelectorPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | property, | ||
overridedefault |
protectedslot |
protectedslot |
protectedslot |
1.8.13 on Sun Dec 14 2025
