vtk3DWidgetRepresentation Class Reference
vtk3DWidgetRepresentation is a vtkDataRepresentation subclass for 3D widgets and their representations. More...
#include <vtk3DWidgetRepresentation.h>
Inheritance diagram for vtk3DWidgetRepresentation:
Collaboration diagram for vtk3DWidgetRepresentation:
enum  DesiredOutputPrecision
void SetWidget (vtkAbstractWidget *)
 Get/Set the widget. More...
virtual vtkAbstractWidgetGetWidget ()
void SetRepresentation (vtkWidgetRepresentation *)
 Get/Set the representation. More...
virtual vtkWidgetRepresentationGetRepresentation ()
virtual void SetUseNonCompositedRenderer (bool)
 Set to true to add the vtkWidgetRepresentation to the non-composited renderer. More...
virtual bool GetUseNonCompositedRenderer ()
virtual void UseNonCompositedRendererOn ()
virtual void UseNonCompositedRendererOff ()
void SetEnabled (bool)
 Get/Set whether the widget is enabled. More...
virtual bool GetEnabled ()
virtual void EnabledOn ()
virtual void EnabledOff ()
void SetReferenceBounds (const double bds[6])
 These are needed to support BoxWidget use-case where we want to support specification of the box using global transform or relative to some reference bounds. More...
void PlaceWidget (const double bds[6])
void SetUseReferenceBounds (bool)
vtkDataRepresentationNewInstance () const
virtual vtkSelectionConvertSelection (vtkView *view, vtkSelection *selection)
vtkAlgorithmOutputGetInputConnection (int port=0, int index=0)
vtkAnnotationLinkGetAnnotationLink ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port, int conn)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort ()
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port, int conn)
virtual vtkAlgorithmOutputGetInternalOutputPort ()
virtual vtkAlgorithmOutputGetInternalOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalOutputPort (int port, int conn)
virtual vtkStringArrayGetSelectionArrayNames ()
vtkPassInputTypeAlgorithmNewInstance () const
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkTableGetTableOutput ()
vtkGraphGetGraphOutput ()
vtkDataObjectGetInput ()
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtk3DWidgetRepresentationNew ()
static vtk3DWidgetRepresentationSafeDownCast (vtkObject *o)
static vtkDataRepresentationNew ()
static vtkDataRepresentationSafeDownCast (vtkObjectBase *o)
static vtkPassInputTypeAlgorithmNew ()
static vtkPassInputTypeAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtk3DWidgetRepresentation ()
 ~vtk3DWidgetRepresentation () override
void UpdateEnabled ()
 Updates 'Enabled' on this->Widget. More...
void OnRepresentationModified ()
 Callback whenever the representation is modified. More...
void OnViewModified ()
 Callback whenever the view is modified. More...
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
virtual vtkAnnotationLayersConvertAnnotations (vtkView *view, vtkAnnotationLayers *annotations)
vtkTrivialProducerGetInternalInput (int port, int conn)
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
virtual int RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
bool Enabled
bool UseNonCompositedRenderer
vtkAbstractWidgetWidget
vtkWidgetRepresentationRepresentation
vtkWeakPointer< vtkPVRenderViewView
bool Selectable
int SelectionType
vtkStringArraySelectionArrayNames
CommandObserver
vtkAnnotationLinkAnnotationLinkInternal
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
It makes it possible to add 3D widgets to vtkPVRenderView.
Definition at line 22 of file vtk3DWidgetRepresentation.h.
Definition at line 26 of file vtk3DWidgetRepresentation.h.
◆ vtk3DWidgetRepresentation()
vtk3DWidgetRepresentation::vtk3DWidgetRepresentation ( )
◆ ~vtk3DWidgetRepresentation()
vtk3DWidgetRepresentation::~vtk3DWidgetRepresentation ( )
static vtk3DWidgetRepresentation* vtk3DWidgetRepresentation::New ( )
virtual const char* vtk3DWidgetRepresentation::GetClassName ( )
static int vtk3DWidgetRepresentation::IsTypeOf ( const char *  type)
virtual int vtk3DWidgetRepresentation::IsA ( const char *  type)
static vtk3DWidgetRepresentation* vtk3DWidgetRepresentation::SafeDownCast ( vtkObject o)
void vtk3DWidgetRepresentation::PrintSelf ( ostream &  os,
◆ SetWidget()
void vtk3DWidgetRepresentation::SetWidget ( vtkAbstractWidget )
Get/Set the widget.
◆ GetWidget()
virtual vtkAbstractWidget* vtk3DWidgetRepresentation::GetWidget ( )
Get/Set the widget.
◆ SetRepresentation()
void vtk3DWidgetRepresentation::SetRepresentation ( vtkWidgetRepresentation )
◆ GetRepresentation()
virtual vtkWidgetRepresentation* vtk3DWidgetRepresentation::GetRepresentation ( )
◆ SetUseNonCompositedRenderer()
virtual void vtk3DWidgetRepresentation::SetUseNonCompositedRenderer ( bool  )
false by default.
◆ GetUseNonCompositedRenderer()
virtual bool vtk3DWidgetRepresentation::GetUseNonCompositedRenderer ( )
false by default.
◆ UseNonCompositedRendererOn()
virtual void vtk3DWidgetRepresentation::UseNonCompositedRendererOn ( )
false by default.
◆ UseNonCompositedRendererOff()
virtual void vtk3DWidgetRepresentation::UseNonCompositedRendererOff ( )
false by default.
◆ SetEnabled()
void vtk3DWidgetRepresentation::SetEnabled ( bool  )
◆ GetEnabled()
virtual bool vtk3DWidgetRepresentation::GetEnabled ( )
◆ EnabledOn()
virtual void vtk3DWidgetRepresentation::EnabledOn ( )
◆ EnabledOff()
virtual void vtk3DWidgetRepresentation::EnabledOff ( )
◆ SetReferenceBounds()
void vtk3DWidgetRepresentation::SetReferenceBounds ( const double  bds[6])
Since this may be applicable to other 3D widgets that have similar requirements, we add this ability to vtk3DWidgetRepresentation itself. All this does it based on the state of UseReferenceBounds, vtkWidgetRepresentation::PlaceWidget is called using either the ReferenceBounds or the bounds passed to PlaceWidget.
◆ PlaceWidget()
void vtk3DWidgetRepresentation::PlaceWidget ( const double  bds[6])
◆ SetUseReferenceBounds()
void vtk3DWidgetRepresentation::SetUseReferenceBounds ( bool  )
◆ AddToView()
bool vtk3DWidgetRepresentation::AddToView ( vtkView view)
◆ RemoveFromView()
bool vtk3DWidgetRepresentation::RemoveFromView ( vtkView view)
◆ UpdateEnabled()
void vtk3DWidgetRepresentation::UpdateEnabled ( )
◆ OnRepresentationModified()
void vtk3DWidgetRepresentation::OnRepresentationModified ( )
We call UpdateEnabled() to ensure that the widget is not left enabled when the representation is hidden.
◆ OnViewModified()
void vtk3DWidgetRepresentation::OnViewModified ( )
If the view's interactor has changed, we will pass that to the vtkAbstractWidget instance and then call UpdateEnabled().
◆ Enabled
bool vtk3DWidgetRepresentation::Enabled
Definition at line 116 of file vtk3DWidgetRepresentation.h.
bool vtk3DWidgetRepresentation::UseNonCompositedRenderer
Definition at line 117 of file vtk3DWidgetRepresentation.h.
◆ Widget
vtkAbstractWidget* vtk3DWidgetRepresentation::Widget
Definition at line 118 of file vtk3DWidgetRepresentation.h.
◆ Representation
vtkWidgetRepresentation* vtk3DWidgetRepresentation::Representation
Definition at line 119 of file vtk3DWidgetRepresentation.h.
◆ View
vtkWeakPointer<vtkPVRenderView> vtk3DWidgetRepresentation::View
Definition at line 120 of file vtk3DWidgetRepresentation.h.
