vtkCPFieldBuilder Class Referenceabstract
Abstract class for specifying fields over grids. More...
#include <vtkCPFieldBuilder.h>
Inheritance diagram for vtkCPFieldBuilder:
Collaboration diagram for vtkCPFieldBuilder:
typedef vtkCPBaseFieldBuilder Superclass
- Public Types inherited from vtkCPBaseFieldBuilder
void BuildField (unsigned long TimeStep, double Time, vtkDataSet *Grid) override=0
 Return a field on Grid. More...
virtual void SetArrayName (const char *)
 Return the highest order of discretization of the field. More...
virtual char * GetArrayName ()
void SetTensorFieldFunction (vtkCPTensorFieldFunction *TFF)
 Set/get TensorFieldFunction. More...
vtkCPTensorFieldFunctionGetTensorFieldFunction ()
static vtkCPFieldBuilderSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPBaseFieldBuilder
static vtkCPBaseFieldBuilderSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkCPFieldBuilder ()
 ~vtkCPFieldBuilder () override
- Protected Member Functions inherited from vtkCPBaseFieldBuilder
 vtkCPBaseFieldBuilder ()
 ~vtkCPBaseFieldBuilder () override
Abstract class for specifying fields over grids for a test driver.
Definition at line 18 of file vtkCPFieldBuilder.h.
Definition at line 21 of file vtkCPFieldBuilder.h.
◆ vtkCPFieldBuilder()
vtkCPFieldBuilder::vtkCPFieldBuilder ( )
◆ ~vtkCPFieldBuilder()
vtkCPFieldBuilder::~vtkCPFieldBuilder ( )
virtual const char* vtkCPFieldBuilder::GetClassName ( )
Reimplemented from vtkCPBaseFieldBuilder.
Reimplemented in vtkCPCellFieldBuilder, and vtkCPNodalFieldBuilder.
static int vtkCPFieldBuilder::IsTypeOf ( const char *  type)
virtual int vtkCPFieldBuilder::IsA ( const char *  type)
static vtkCPFieldBuilder* vtkCPFieldBuilder::SafeDownCast ( vtkObject o)
void vtkCPFieldBuilder::PrintSelf ( ostream &  os,
Reimplemented in vtkCPNodalFieldBuilder.
◆ BuildField()
void vtkCPFieldBuilder::BuildField ( unsigned long  TimeStep,
double  Time,
vtkDataSet Grid
overridepure virtual
Implements vtkCPBaseFieldBuilder.
Implemented in vtkCPCellFieldBuilder, and vtkCPNodalFieldBuilder.
◆ SetArrayName()
virtual void vtkCPFieldBuilder::SetArrayName ( const char *  )
virtual unsigned int GetHighestFieldOrder() = 0; Set/get the name of the field array.
◆ GetArrayName()
virtual char* vtkCPFieldBuilder::GetArrayName ( )
◆ SetTensorFieldFunction()
void vtkCPFieldBuilder::SetTensorFieldFunction ( vtkCPTensorFieldFunction TFF)
◆ GetTensorFieldFunction()
vtkCPTensorFieldFunction* vtkCPFieldBuilder::GetTensorFieldFunction ( )
