representation for rendering surfaces of cell-grid datasets. More...
#include <vtkCellGridRepresentation.h>
| typedef vtkGeometryRepresentation | Superclass |
Public Types inherited from vtkGeometryRepresentation | |
| enum | RepresentationTypes { POINTS = VTK_POINTS, WIREFRAME = VTK_WIREFRAME, SURFACE = VTK_SURFACE, SURFACE_WITH_EDGES = 3 } |
| typedef vtkPVDataRepresentation | Superclass |
Public Types inherited from vtkPVDataRepresentation | |
| enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
| typedef vtkDataRepresentation | Superclass |
Public Types inherited from vtkDataRepresentation | |
| typedef vtkPassInputTypeAlgorithm | Superclass |
Public Types inherited from vtkPassInputTypeAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
| void | SetVisibility (bool val) override |
| Get/Set the visibility for this representation. More... | |
| void | SetSuppressLOD (bool vtkNotUsed(suppress)) override |
| Enable/Disable LOD;. More... | |
| void | SetSidesToShow (int flags) |
| Set which sides of the input to show. More... | |
| void | SetPreserveRenderableInputs (bool shouldPreserve) |
| Set whether to preserve renderable inputs. More... | |
| void | SetOmitSidesForRenderableInputs (bool shouldOmit) |
| Set whether to omit sides for renderable inputs. More... | |
Public Member Functions inherited from vtkGeometryRepresentation | |
| virtual void | SetSuppressLOD (bool suppress) |
| virtual void | SetRepresentation (const char *) |
| Overload to set representation type using string. More... | |
| vtkDataObject * | GetRenderedDataObject (int port) override |
| Returns the data object that is rendered from the given input port. More... | |
| virtual void | SetNormalArray (const char *val) |
| Set the normal array used for smooth shading. More... | |
| virtual void | SetTCoordArray (const char *val) |
| Set the texture coordinates array used for texture mapping. More... | |
| virtual void | SetTangentArray (const char *val) |
| Set the tangent coordinates array used for normal mapping. More... | |
| virtual void | SetUseOutline (int) |
| void | SetTriangulate (int) |
| void | SetNonlinearSubdivisionLevel (int) |
| void | SetMatchBoundariesIgnoringCellOrder (int) |
| virtual void | SetGenerateFeatureEdges (bool) |
| void | SetComputePointNormals (bool) |
| void | SetSplitting (bool) |
| void | SetFeatureAngle (double) |
| virtual void | SetAmbientColor (double r, double g, double b) |
| virtual void | SetColor (double r, double g, double b) |
| virtual void | SetDiffuseColor (double r, double g, double b) |
| virtual void | SetLighting (bool lighting) |
| virtual void | SetEdgeColor (double r, double g, double b) |
| virtual void | SetInteractiveSelectionColor (double r, double g, double b) |
| virtual void | SetInterpolation (int val) |
| virtual void | SetLineWidth (double val) |
| virtual void | SetOpacity (double val) |
| virtual void | SetEdgeOpacity (double val) |
| virtual void | SetPointSize (double val) |
| virtual void | SetSpecularColor (double r, double g, double b) |
| virtual void | SetSpecularPower (double val) |
| virtual void | SetLuminosity (double val) |
| virtual void | SetRenderPointsAsSpheres (bool) |
| virtual void | SetRenderLinesAsTubes (bool) |
| virtual void | SetRoughness (double val) |
| virtual void | SetMetallic (double val) |
| virtual void | SetEdgeTint (double r, double g, double b) |
| virtual void | SetAnisotropy (double val) |
| virtual void | SetAnisotropyRotation (double val) |
| virtual void | SetBaseIOR (double val) |
| virtual void | SetCoatIOR (double val) |
| virtual void | SetCoatStrength (double val) |
| virtual void | SetCoatRoughness (double val) |
| virtual void | SetCoatNormalScale (double val) |
| virtual void | SetCoatColor (double r, double g, double b) |
| virtual void | SetBaseColorTexture (vtkTexture *tex) |
| virtual void | SetMaterialTexture (vtkTexture *tex) |
| virtual void | SetAnisotropyTexture (vtkTexture *tex) |
| virtual void | SetNormalTexture (vtkTexture *tex) |
| virtual void | SetCoatNormalTexture (vtkTexture *tex) |
| virtual void | SetEmissiveTexture (vtkTexture *tex) |
| virtual void | SetNormalScale (double val) |
| virtual void | SetOcclusionStrength (double val) |
| virtual void | SetEmissiveFactor (double rval, double gval, double bval) |
| virtual void | SetShowTexturesOnBackface (bool) |
| virtual void | SetOrientation (double, double, double) |
| virtual void | SetOrigin (double, double, double) |
| virtual void | SetPickable (int val) |
| virtual void | SetPosition (double, double, double) |
| virtual void | SetScale (double, double, double) |
| virtual void | SetTexture (vtkTexture *) |
| virtual void | SetUserTransform (const double[16]) |
| virtual void | SetCoordinateSystem (int) |
| virtual void | SetTextureTransform (vtkTransform *) |
| virtual vtkTransform * | GetTextureTransform () |
| virtual void | SetRepeatTextures (bool) |
| virtual bool | GetRepeatTextures () |
| virtual void | SetInterpolateTextures (bool) |
| virtual bool | GetInterpolateTextures () |
| virtual void | SetUseMipmapTextures (bool) |
| virtual bool | GetUseMipmapTextures () |
| virtual void | SetInterpolateScalarsBeforeMapping (int val) |
| virtual void | SetLookupTable (vtkScalarsToColors *val) |
| virtual void | SetColorMissingArraysWithNanColor (bool val) |
| virtual void | SetSeamlessU (bool) |
| virtual void | SetSeamlessV (bool) |
| virtual void | SetSelection (vtkSelection *selection) |
| Sets the selection used by the mapper. More... | |
| vtkPVLODActor * | GetActor () |
| Provides access to the actor used by this representation. More... | |
| const char * | GetColorArrayName () |
| Convenience method to get the array name used to scalar color with. More... | |
| virtual void | SetMaterial (const char *) |
| For OSPRay, choose from among available materials. More... | |
| virtual void | SetShaderReplacements (const char *) |
| Specify shader replacements using a Json string. More... | |
| void | SetArrayIdNames (const char *pointArray, const char *cellArray) override |
| Specify the array names used for the selection. More... | |
| void | SetBlockColorsDistinctValues (int distinctValues) |
| Determines the number of distinct values in vtkBlockColors See also vtkPVGeometryFilter. More... | |
| int | GetBlockColorsDistinctValues () |
| virtual void | DisableLightingOn () |
| Disables the lighting on the object. More... | |
| virtual void | DisableLightingOff () |
| virtual void | SetDisableLighting (bool) |
| virtual bool | GetDisableLighting () |
| virtual void | SetAmbient (double) |
| Set the lighting properties of the object. More... | |
| virtual void | SetDiffuse (double) |
| virtual void | SetSpecular (double) |
| virtual double | GetAmbient () |
| virtual double | GetDiffuse () |
| virtual double | GetSpecular () |
| void | SetCoordinateShiftScaleMethod (int val) |
| Set the shift scale method for the point coordinates see vtkOpenGLVertexBufferObject.h for more information. More... | |
| int | GetCoordinateShiftScaleMethod () |
| virtual void | SetRepresentation (int) |
| Set the representation type. More... | |
| virtual int | GetRepresentation () |
| virtual void | SetRequestGhostCellsIfNeeded (bool) |
| Representations that use geometry representation as the internal representation should turn this flag off so that we don't end up requesting ghost cells twice. More... | |
| virtual bool | GetRequestGhostCellsIfNeeded () |
| virtual void | RequestGhostCellsIfNeededOn () |
| virtual void | RequestGhostCellsIfNeededOff () |
| virtual void | SetMapScalars (int val) |
| Sets if scalars are mapped through a color-map or are used directly as colors. More... | |
| virtual void | SetStatic (int val) |
| virtual void | SetActiveAssembly (const char *) |
| Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More... | |
| virtual char * | GetActiveAssembly () |
| void | AddBlockSelector (const char *selector) |
| Update list of selectors that determine the selected blocks. More... | |
| void | RemoveAllBlockSelectors () |
| void | SetBlockColor (const char *selector, double r, double g, double b) |
| Set the color for a single block. More... | |
| void | RemoveAllBlockColors () |
| void | SetBlockOpacity (const char *selector, double opacity) |
| Set the opacity for a single block. More... | |
| void | RemoveAllBlockOpacities () |
| void | SetBlockInterpolateScalarsBeforeMapping (const char *selector, bool interpolate) |
| Set if to interpolate scalars before mapping for a single block. More... | |
| void | RemoveAllBlockInterpolateScalarsBeforeMappings () |
| void | SetBlockMapScalars (const char *selector, int val) |
| Set the block to map scalars for a single block. More... | |
| void | RemoveAllBlockMapScalars () |
| void | SetBlockArrayName (const char *selector, int assoc, const char *arrayName) |
| Set the color array for a single block. More... | |
| void | RemoveAllBlockArrayNames () |
| void | SetBlockLookupTable (vtkScalarsToColors *lut) |
| Set the look up table for a single block. More... | |
| void | RemoveAllBlockLookupTables () |
| virtual void | SetEnableScaling (int v) |
| For OSPRay controls sizing of implicit spheres (points) and cylinders (lines) More... | |
| virtual void | SetScalingArrayName (const char *) |
| virtual void | SetScalingFunction (vtkPiecewiseFunction *pwf) |
| virtual void | SetUseDataPartitions (bool) |
| Specify whether or not to redistribute the data. More... | |
| virtual bool | GetUseDataPartitions () |
| virtual void | SetUseShaderReplacements (bool) |
| Specify whether or not to shader replacements string must be used. More... | |
| virtual bool | GetUseShaderReplacements () |
| void | SetPlaceHolderDataType (int datatype) |
| Set/Get the placeholder data type. More... | |
| virtual int | GetPlaceHolderDataType () |
Public Member Functions inherited from vtkPVDataRepresentation | |
| virtual void | MarkModified () |
| This is one of the most important functions. More... | |
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| Initialize the representation with an identifier range so each internal representation can own a unique ID. More... | |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
| Returns the cache-key the representation is currently using. More... | |
| Retrieves an output port for the input data object at the specified port and connection index. More... | |
| Provides access to the view. More... | |
Returns the timestamp when RequestData was executed on the representation. More... | |
| bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More... | |
| Set the update time. More... | |
| Get whether the UpdateTime is valid. More... | |
| void | ResetUpdateTime () |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
| Making these methods public. More... | |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| This flag indicates if the representation is for a temporal pipeline. More... | |
Overridden to ensure that MarkModified is called. More... | |
Public Member Functions inherited from vtkDataRepresentation | |
Public Member Functions inherited from vtkPassInputTypeAlgorithm | |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
vtkCellGridRepresentation is a representation for showing surfaces of finite-element cell-grids. It handles volumetric datasets by computing arrays of external-surface (cell-ID, side-ID)-tuples and rendering those.
It can also render existing (cell-ID, side-ID) tuple-arrays to illustrate the domains of imposed boundary- and initial-conditions.
Definition at line 21 of file vtkCellGridRepresentation.h.
Definition at line 26 of file vtkCellGridRepresentation.h.
Reimplemented from vtkGeometryRepresentation.
When the visibility of representation of false, all view passes are ignored.
inlineoverride |
Definition at line 47 of file vtkCellGridRepresentation.h.
| void vtkCellGridRepresentation::SetSidesToShow | ( | int | flags | ) |
| void vtkCellGridRepresentation::SetPreserveRenderableInputs | ( | bool | shouldPreserve | ) |
| void vtkCellGridRepresentation::SetOmitSidesForRenderableInputs | ( | bool | shouldOmit | ) |
overrideprotectedvirtual |
This method is called in the constructor.
If the subclasses override any of the iVar vtkObject's of this class e.g. the Mappers, GeometryFilter etc., they should call this method again in their constructor. It must be totally safe to call this method repeatedly.
Fill input port information.
Subclasses should override this to connect inputs to the internal pipeline as necessary.
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
Passes on parameters to vtkProperty and vtkMapper.
Returns true if this representation has translucent geometry.
Unlike vtkActor::HasTranslucentPolygonalGeometry which cannot be called in Update, this method can be called in Update i.e. before the mapper has all the data to decide if it is doing translucent rendering.
1.8.13 on Sat Dec 13 2025
