vtkCellGridRepresentation.h
16 #ifndef vtkCellGridRepresentation_h
17 #define vtkCellGridRepresentation_h
18
20
22 {
23
24 public:
27  void PrintSelf(ostream& os, vtkIndent indent) override;
28
36  vtkInformation* outInfo) override;
37
42  void SetVisibility(bool val) override;
43
47  void SetSuppressLOD(bool vtkNotUsed(suppress)) override {} // We do not support LOD yet.
48
52  void SetSidesToShow(int flags);
53
57  void SetPreserveRenderableInputs(bool shouldPreserve);
58
62  void SetOmitSidesForRenderableInputs(bool shouldOmit);
63
64 protected:
66  ~vtkCellGridRepresentation() override;
67
74  void SetupDefaults() override;
75
80
92
98  bool AddToView(vtkView* view) override;
99
105  bool RemoveFromView(vtkView* view) override;
106
110  void UpdateColoringParameters() override;
111
118  bool NeedsOrderedCompositing() override;
119
120 #if 0
121
124  virtual void SetPointArrayToProcess(int p, const char* val);
125 #endif
126
127 private:
129  void operator=(const vtkCellGridRepresentation&) = delete;
130 };
131
132 #endif
int ProcessViewRequest(vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo) override
int FillInputPortInformation(int port, vtkInformation *info) override
Fill input port information.
virtual void SetupDefaults()
This method is called in the constructor.
info
representation for rendering surfaces of cell-grid datasets.
Enable/Disable LOD;.
representation for showing any datasets as external shell of polygons.
static vtkGeometryRepresentation * New()
virtual void UpdateColoringParameters()
Passes on parameters to vtkProperty and vtkMapper.
virtual void SetPointArrayToProcess(int p, const char *val)
Used by SetNormalArray, SetTCoordArray and SetTangentArray.
bool AddToView(vtkView *view) override
bool RemoveFromView(vtkView *view) override
int RequestData(vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
Subclasses should override this to connect inputs to the internal pipeline as necessary.
port
virtual bool NeedsOrderedCompositing()
Returns true if this representation has translucent geometry.
