virtual void | SetReadAsImageStack (bool) |
virtual bool | GetReadAsImageStack () |
virtual void | ReadAsImageStackOn () |
virtual void | ReadAsImageStackOff () |
int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| Overridden to directly call the internal reader after passing it the correct filenames when ReadAsImageStack is true. More...
virtual int | CanReadFile (const char *filename) |
| CanReadFile is forwarded to the internal reader if it supports it. More...
virtual void | AddFileName (const char *fname) |
| Adds names of files to be read. More...
virtual void | RemoveAllFileNames () |
| Remove all file names. More...
virtual unsigned int | GetNumberOfFileNames () |
| Returns the number of file names added by AddFileName. More...
virtual const char * | GetFileName (unsigned int idx) |
| Returns the name of a file with index idx. More...
const char * | GetCurrentFileName () |
unsigned long | GetErrorCode () override |
| Return the error code of the reader. More...
virtual int | GetUseMetaFile () |
| If true, then use the meta file. More...
virtual void | SetUseMetaFile (int) |
virtual void | UseMetaFileOn () |
virtual void | UseMetaFileOff () |
virtual bool | GetIgnoreReaderTime () |
| If true, then treat file series like it does not contain any time step values. More...
virtual void | SetIgnoreReaderTime (bool) |
virtual void | IgnoreReaderTimeOn () |
virtual void | IgnoreReaderTimeOff () |
| vtkMetaReader () |
| ~vtkMetaReader () override |
vtkMTimeType | GetMTime () override |
| Return the MTime when also considering the internal reader. More...
virtual void | SetReader (vtkAlgorithm *) |
| Set/get the internal reader. More...
virtual vtkAlgorithm * | GetReader () |
void | SetMetaFileName (const char *name) |
| Get/set the filename for the meta-file. More...
char * | GetMetaFileName () |
virtual vtkIdType * | GetFileIndexRange () |
| Returns the available range of file indexes. More...
virtual void | GetFileIndexRange (vtkIdType &, vtkIdType &) |
virtual void | GetFileIndexRange (vtkIdType [2]) |
vtkIdType | GetFileIndex () |
| Get/set the index of the file to read. More...
void | SetFileIndex (vtkIdType i) |
virtual void | SetFileNameMethod (const char *) |
| Name of the method used to set the file name of the internal reader. More...
virtual char * | GetFileNameMethod () |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkImageFileSeriesReader () |
| ~vtkImageFileSeriesReader () override |
void | UpdateFileNames () |
virtual void | UpdateReaderDataExtent () |
| Update the reader extent if the image file format does not know what it is (e.g. More...
| vtkFileSeriesReader () |
| ~vtkFileSeriesReader () override |
int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
virtual int | RequestUpdateTimeDependentInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
int | FillOutputPortInformation (int port, vtkInformation *info) override |
virtual int | RequestInformationForInput (int index, vtkInformation *request=nullptr, vtkInformationVector *outputVector=nullptr) |
| Make sure the reader's output is set to the given index and, if it changed, run RequestInformation on the reader. More...
virtual int | ReadMetaDataFile (const char *metafilename, vtkStringArray *filesToRead, std::vector< double > &timeValues, int maxFilesToRead=VTK_INT_MAX) |
| Reads a metadata file and returns a list of filenames (in filesToRead). More...
virtual void | UpdateMetaData () |
| Re-reads information from the metadata file, if necessary. More...
void | ResetTimeRanges () |
| Resets information about TimeRanges. More...
void | RemoveAllFileNamesInternal () |
| Add/Remove filenames without changing the MTime. More...
void | AddFileNameInternal (const char *) |
virtual void | RemoveAllRealFileNamesInternal () |
| Remove all real file names. More...
void | CopyRealFileNamesFromFileNames () |
| Set the real filenames to those in the internal FileNames. More...
int | ChooseInput (vtkInformation *) |
virtual void | Set_MetaFileName (const char *) |
virtual char * | Get_MetaFileName () |
virtual void | Set_FileIndex (vtkIdType) |
virtual vtkIdType | Get_FileIndex () |
void | ReaderSetFileName (const char *filename) |
int | ReaderCanReadFile (const char *filename) |
std::string | FromRelativeToMetaFile (const char *metaFileName, const char *fileName) |
| 'metaFileName' to either a file path that is relative to the current working directory (CWD) or to an absolute file path. More...
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkDataObjectAlgorithm () |
| ~vtkDataObjectAlgorithm () |
virtual int | FillInputPortInformation (int port, vtkInformation *info) |
virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
virtual vtkExecutive * | CreateDefaultExecutive () |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
adds support for optionally reading image stacks.
vtkImageFileSeriesReader is designed for vtkImageReader2 and subclasses. This adds API to optionally treat the file series as an image stack rather than a temporal dataset. When ReadAsImageStack is true, we simply by-pass the superclass and instead pass all filenames to the internal reader and then let it handle the pipeline requests.
Definition at line 22 of file vtkImageFileSeriesReader.h.
