adds support for optionally reading raw image stacks. More...
#include <vtkRawImageFileSeriesReader.h>
| typedef vtkImageFileSeriesReader | Superclass |
Public Types inherited from vtkImageFileSeriesReader | |
| typedef vtkFileSeriesReader | Superclass |
Public Types inherited from vtkFileSeriesReader | |
| typedef vtkMetaReader | Superclass |
Public Types inherited from vtkMetaReader | |
| typedef vtkDataObjectAlgorithm | Superclass |
Public Types inherited from vtkDataObjectAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| virtual void | SetFileDimensionality (int) |
| The number of dimensions stored in a file. More... | |
| virtual int | GetFileDimensionality () |
| virtual void | SetDimensions (int, int, int) |
| Dimensions defines the size of the data, and MinimumIndex defines the starting index. More... | |
| virtual void | SetDimensions (int [3]) |
| virtual int * | GetDimensions () |
| virtual void | GetDimensions (int &, int &, int &) |
| virtual void | GetDimensions (int [3]) |
| virtual int * | GetMinimumIndex () |
| virtual void | GetMinimumIndex (int &, int &, int &) |
| virtual void | GetMinimumIndex (int [3]) |
| virtual void | SetMinimumIndex (int, int, int) |
| virtual void | SetMinimumIndex (int [3]) |
Public Member Functions inherited from vtkImageFileSeriesReader | |
| virtual void | SetReadAsImageStack (bool) |
| virtual bool | GetReadAsImageStack () |
| virtual void | ReadAsImageStackOn () |
| virtual void | ReadAsImageStackOff () |
| int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| Overridden to directly call the internal reader after passing it the correct filenames when ReadAsImageStack is true. More... | |
Public Member Functions inherited from vtkFileSeriesReader | |
| virtual int | CanReadFile (const char *filename) |
| CanReadFile is forwarded to the internal reader if it supports it. More... | |
| virtual void | AddFileName (const char *fname) |
| Adds names of files to be read. More... | |
| virtual void | RemoveAllFileNames () |
| Remove all file names. More... | |
| virtual unsigned int | GetNumberOfFileNames () |
| Returns the number of file names added by AddFileName. More... | |
| virtual const char * | GetFileName (unsigned int idx) |
| Returns the name of a file with index idx. More... | |
| const char * | GetCurrentFileName () |
| unsigned long | GetErrorCode () override |
| Return the error code of the reader. More... | |
| virtual int | GetUseMetaFile () |
| If true, then use the meta file. More... | |
| virtual void | SetUseMetaFile (int) |
| virtual void | UseMetaFileOn () |
| virtual void | UseMetaFileOff () |
| virtual bool | GetIgnoreReaderTime () |
| If true, then treat file series like it does not contain any time step values. More... | |
| virtual void | SetIgnoreReaderTime (bool) |
| virtual void | IgnoreReaderTimeOn () |
| virtual void | IgnoreReaderTimeOff () |
Public Member Functions inherited from vtkMetaReader | |
| vtkMetaReader () | |
| ~vtkMetaReader () override | |
| vtkMTimeType | GetMTime () override |
| Return the MTime when also considering the internal reader. More... | |
| virtual void | SetReader (vtkAlgorithm *) |
| Set/get the internal reader. More... | |
| virtual vtkAlgorithm * | GetReader () |
| void | SetMetaFileName (const char *name) |
| Get/set the filename for the meta-file. More... | |
| char * | GetMetaFileName () |
| virtual vtkIdType * | GetFileIndexRange () |
| Returns the available range of file indexes. More... | |
| virtual void | GetFileIndexRange (vtkIdType &, vtkIdType &) |
| virtual void | GetFileIndexRange (vtkIdType [2]) |
| vtkIdType | GetFileIndex () |
| Get/set the index of the file to read. More... | |
| void | SetFileIndex (vtkIdType i) |
| virtual void | SetFileNameMethod (const char *) |
| Name of the method used to set the file name of the internal reader. More... | |
| virtual char * | GetFileNameMethod () |
Public Member Functions inherited from vtkDataObjectAlgorithm | |
| vtkDataObjectAlgorithm * | NewInstance () const |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
Protected Attributes | |
| int | Dimensions [3] |
| Raw files don't have any extent information in them and are required to be set by the user. More... | |
| int | MinimumIndex [3] |
| int | FileDimensionality |
| The dimensionality that we pass to the actual image reader. More... | |
Protected Attributes inherited from vtkImageFileSeriesReader | |
| bool | ReadAsImageStack |
Protected Attributes inherited from vtkFileSeriesReader | |
| int | UseMetaFile |
| True if use a meta-file, false otherwise. More... | |
| bool | UseJsonMetaFile |
| True if meta-file is of Json format, false otherwise. More... | |
| bool | IgnoreReaderTime |
Protected Attributes inherited from vtkMetaReader | |
| vtkAlgorithm * | Reader |
| vtkMTimeType | FileNameMTime |
| vtkMTimeType | BeforeFileNameMTime |
| char * | FileNameMethod |
| vtkIdType | _FileIndex |
| vtkMTimeType | FileIndexMTime |
| vtkIdType | FileIndexRange [2] |
| char * | _MetaFileName |
| vtkMTimeType | MetaFileNameMTime |
| vtkTimeStamp | MetaFileReadTime |
| Records the time when the meta-file was read. More... | |
Protected Attributes inherited from vtkAlgorithm | |
| vtkInformation * | Information |
| double | Progress |
| char * | ProgressText |
| vtkProgressObserver * | ProgressObserver |
| unsigned long | ErrorCode |
Public Attributes inherited from vtkAlgorithm | |
| SINGLE_PRECISION | |
| DOUBLE_PRECISION | |
| DEFAULT_PRECISION | |
| int | AbortExecute |
Static Protected Member Functions inherited from vtkAlgorithm | |
| static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
Static Protected Attributes inherited from vtkAlgorithm | |
| static vtkExecutive * | DefaultExecutivePrototype |
vtkRawImageFileSeriesReader is designed to read in raw files. The issue with raw files is that the extents are not known and must be passed to vtkImageReader2 and subclasses.
Definition at line 18 of file vtkRawImageFileSeriesReader.h.
Definition at line 22 of file vtkRawImageFileSeriesReader.h.
Reimplemented from vtkImageFileSeriesReader.
This defaults to two.
Together, they give the DataExtent as: DataExtent[i] = MinimumIndex[i] + Dimensions[i] - 1
overrideprotectedvirtual |
Update the reader extent if the image file format does not know what it is (e.g.
the raw format). Here we pass in values set by the user.
If we are reading a 2D raw image as a stack we fill in the 3rd extent automatically for the reader actually reading the files and ignore the 3rd extent here. We do need to keep that extent in case the user switches between reading as a stack or reading as a time series.
Definition at line 67 of file vtkRawImageFileSeriesReader.h.
Definition at line 68 of file vtkRawImageFileSeriesReader.h.
Default is 2.
Definition at line 76 of file vtkRawImageFileSeriesReader.h.
1.8.13 on Sun Dec 14 2025
