vtkNetworkAccessManager Class Referenceabstract
vtkNetworkAccessManager is used to create new connections and monitor activity of those connections. More...
#include <vtkNetworkAccessManager.h>
Inheritance diagram for vtkNetworkAccessManager:
Collaboration diagram for vtkNetworkAccessManager:
enum  ConnectionResult {
  ConnectionResult::CONNECTION_SUCCESS, ConnectionResult::CONNECTION_TIMEOUT, ConnectionResult::CONNECTION_ABORT, ConnectionResult::CONNECTION_HANDSHAKE_ERROR,
  ConnectionResult::CONNECTION_FAILURE
 Possible result of connection when creating a new connection CONNECTION_SUCCESS: Connection was sucessfull CONNECTION_TIMEOUT: After spending a specified amount of time, no connection was initiated CONNECTION_ABORT: User aborted the connection before it was successful or timed out CONNECTION_HANDSHAKE_ERROR: Connection was iniated but the handshake failed CONNECTION_FAILURE: Unspecified connection error. More...
virtual void AbortPendingConnection ()=0
 Used to abort pending connection creation, if any. More...
virtual int ProcessEvents (unsigned long timeout_msecs)=0
 Process any network activity. More...
virtual bool GetNetworkEventsAvailable ()=0
 Peeks to check if any activity is available. More...
virtual bool GetPendingConnectionsPresent ()=0
 Returns true is the manager is currently waiting for any connections. More...
virtual void DisableFurtherConnections (int port, bool disable)=0
 Enable/disable further connections for given port. More...
virtual bool GetWrongConnectID ()=0
 Returns true if the last check of connect ids was wrong. More...
virtual vtkMultiProcessControllerNewConnection (const char *url)
 Creates a new connection given the url. More...
virtual vtkMultiProcessControllerNewConnection (const char *url, ConnectionResult &result)=0
static vtkNetworkAccessManagerSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkNetworkAccessManager ()
 ~vtkNetworkAccessManager () override
This is an abstract class that defines the interface. Concrete implementations of this class can be written to support tcp/ip socket or ssl or ssh based network connections among processes.
Definition at line 20 of file vtkNetworkAccessManager.h.
Definition at line 23 of file vtkNetworkAccessManager.h.
◆ ConnectionResult
Enumerator
CONNECTION_SUCCESS
CONNECTION_TIMEOUT
CONNECTION_ABORT
CONNECTION_FAILURE
Definition at line 34 of file vtkNetworkAccessManager.h.
◆ vtkNetworkAccessManager()
vtkNetworkAccessManager::vtkNetworkAccessManager ( )
◆ ~vtkNetworkAccessManager()
vtkNetworkAccessManager::~vtkNetworkAccessManager ( )
virtual const char* vtkNetworkAccessManager::GetClassName ( )
Reimplemented in vtkTCPNetworkAccessManager.
static int vtkNetworkAccessManager::IsTypeOf ( const char *  type)
virtual int vtkNetworkAccessManager::IsA ( const char *  type)
static vtkNetworkAccessManager* vtkNetworkAccessManager::SafeDownCast ( vtkObject o)
void vtkNetworkAccessManager::PrintSelf ( ostream &  os,
◆ NewConnection() [1/2]
virtual vtkMultiProcessController* vtkNetworkAccessManager::NewConnection ( const char *  url)
inlinevirtual
This call may block until the connection can be established. To keep user-interfaces responsive, one can listen to the vtkCommand::ProgressEvent fired periodically by this class while waiting. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
vtkNetworkAccessManager can be waiting for atmost one connection at a time. Calling NewConnection() while another connection is pending will raise an error.
To abort the connection and cancel the waiting, simply call AbortPendingConnection() in the vtkCommand::ProgressEvent callback.
Returns the new connection instance on success, otherwise nullptr.
URLs are of the following form: <transport>://<address>
  • tcp://<hostname>:<port>
  • tcp://localhost:<port>/listen – listen for connection on port.
  • tcp://localhost:<port>/listenmultiple – listen for multiple Examples:
  • tcp://medea:12345
  • tcp://localhost:12345/listen
  • ssh://utkarsh@medea
  • http://kitware-server/session?id=12322&authorization=12
Definition at line 72 of file vtkNetworkAccessManager.h.
◆ NewConnection() [2/2]
virtual vtkMultiProcessController* vtkNetworkAccessManager::NewConnection ( const char *  url,
ConnectionResult result
pure virtual
  • tcp://medea:12345
Implemented in vtkTCPNetworkAccessManager.
◆ AbortPendingConnection()
virtual void vtkNetworkAccessManager::AbortPendingConnection ( )
pure virtual
Refer to NewConnection() for details.
◆ ProcessEvents()
virtual int vtkNetworkAccessManager::ProcessEvents ( unsigned long  timeout_msecs)
pure virtual
◆ GetNetworkEventsAvailable()
virtual bool vtkNetworkAccessManager::GetNetworkEventsAvailable ( )
pure virtual
When this call returns true, ProcessEvents() will always result in some activity processing if called afterword.
◆ GetPendingConnectionsPresent()
virtual bool vtkNetworkAccessManager::GetPendingConnectionsPresent ( )
pure virtual
◆ DisableFurtherConnections()
virtual void vtkNetworkAccessManager::DisableFurtherConnections ( int  port,
bool  disable
pure virtual
◆ GetWrongConnectID()
virtual bool vtkNetworkAccessManager::GetWrongConnectID ( )
pure virtual
