void | AbortPendingConnection () override |
| Used to abort pending connection creation, if any. More...
int | ProcessEvents (unsigned long timeout_msecs) override |
| Process any network activity. More...
bool | GetNetworkEventsAvailable () override |
| Peeks to check if any activity is available. More...
bool | GetPendingConnectionsPresent () override |
| Returns true is the manager is currently waiting for any connections. More...
void | DisableFurtherConnections (int port, bool disable) override |
| Enable/disable further connections for given port. More...
bool | GetWrongConnectID () override |
| Returns true if the last check of connect ids was wrong. More...
vtkMultiProcessController * | NewConnection (const char *url, vtkNetworkAccessManager::ConnectionResult &result) override |
| Creates a new connection given the url. More...
virtual vtkMultiProcessController * | NewConnection (const char *url) |
virtual void | Modified () |
| vtkTCPNetworkAccessManager () |
| ~vtkTCPNetworkAccessManager () override |
int | ProcessEventsInternal (unsigned long timeout_msecs, bool do_processing) |
vtkMultiProcessController * | ConnectToRemote (const char *hostname, int port, const char *handshake, int timeout_in_seconds, vtkNetworkAccessManager::ConnectionResult &result) |
| Connects to remote processes. More...
vtkMultiProcessController * | WaitForConnection (int port, bool once, const char *handshake, bool nonblocking, vtkNetworkAccessManager::ConnectionResult &result) |
| Waits for connection from remote process. More...
int | ParaViewHandshake (vtkMultiProcessController *controller, bool server_side, const char *handshake) |
void | PrintHandshakeError (int errorcode, bool server_side) |
int | AnalyzeHandshakeAndGetErrorCode (const char *clientHS, const char *serverHS) |
| vtkNetworkAccessManager () |
| ~vtkNetworkAccessManager () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
vtkTCPNetworkAccessManager is a concrete implementation of vtkNetworkAccessManager that uses tcp/ip sockets for communication between processes.
It supports urls that use "tcp" as their protocol specifier.
Definition at line 19 of file vtkTCPNetworkAccessManager.h.
This call may block until the connection can be established. To keep user-interfaces responsive, one can listen to the vtkCommand::ProgressEvent fired periodically by this class while waiting. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
vtkNetworkAccessManager can be waiting for atmost one connection at a time. Calling NewConnection() while another connection is pending will raise an error.
To abort the connection and cancel the waiting, simply call AbortPendingConnection() in the vtkCommand::ProgressEvent callback.
Returns the new connection instance on success, otherwise nullptr.
URLs are of the following form: <transport>
://<address>
tcp://<hostname>
:<port>
tcp://localhost
:<port>/listen – listen for connection on port.
tcp://localhost
:<port>/listenmultiple – listen for multiple Examples:
tcp://medea
:12345
tcp://localhost
:12345/listen
ssh://utkarsh@medea
- http://kitware-server/session?id=12322&authorization=12
Implements vtkNetworkAccessManager.
