representation for outline. More...
#include <vtkOutlineRepresentation.h>
| typedef vtkGeometryRepresentationWithFaces | Superclass |
Public Types inherited from vtkGeometryRepresentationWithFaces | |
| enum | RepresentationTypesEx { FOLLOW_FRONTFACE = 400, CULL_BACKFACE = 401, CULL_FRONTFACE = 402 } |
| typedef vtkGeometryRepresentation | Superclass |
Public Types inherited from vtkGeometryRepresentation | |
| enum | RepresentationTypes { POINTS = VTK_POINTS, WIREFRAME = VTK_WIREFRAME, SURFACE = VTK_SURFACE, SURFACE_WITH_EDGES = 3 } |
| typedef vtkPVDataRepresentation | Superclass |
Public Types inherited from vtkPVDataRepresentation | |
| enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
| typedef vtkDataRepresentation | Superclass |
Public Types inherited from vtkDataRepresentation | |
| typedef vtkPassInputTypeAlgorithm | Superclass |
Public Types inherited from vtkPassInputTypeAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| void | SetRepresentation (const char *) override |
| Overload to set representation type using string. More... | |
| void | SetUseOutline (int) override |
| void | SetSuppressLOD (bool) override |
| Enable/Disable LOD;. More... | |
| void | SetPickable (int) override |
Public Member Functions inherited from vtkGeometryRepresentationWithFaces | |
| vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
| void | SetVisibility (bool val) override |
| Get/Set the visibility for this representation. More... | |
| void | SetBackfaceAmbientColor (double r, double g, double b) |
| void | SetBackfaceDiffuseColor (double r, double g, double b) |
| void | SetBackfaceOpacity (double val) |
| virtual void | SetBackfaceRepresentation (int) |
| Set the backface representation. More... | |
| virtual int | GetBackfaceRepresentation () |
Public Member Functions inherited from vtkGeometryRepresentation | |
| vtkDataObject * | GetRenderedDataObject (int port) override |
| Returns the data object that is rendered from the given input port. More... | |
| virtual void | SetNormalArray (const char *val) |
| Set the normal array used for smooth shading. More... | |
| virtual void | SetTCoordArray (const char *val) |
| Set the texture coordinates array used for texture mapping. More... | |
| virtual void | SetTangentArray (const char *val) |
| Set the tangent coordinates array used for normal mapping. More... | |
| void | SetTriangulate (int) |
| void | SetNonlinearSubdivisionLevel (int) |
| void | SetMatchBoundariesIgnoringCellOrder (int) |
| virtual void | SetGenerateFeatureEdges (bool) |
| void | SetComputePointNormals (bool) |
| void | SetSplitting (bool) |
| void | SetFeatureAngle (double) |
| virtual void | SetAmbientColor (double r, double g, double b) |
| virtual void | SetColor (double r, double g, double b) |
| virtual void | SetDiffuseColor (double r, double g, double b) |
| virtual void | SetLighting (bool lighting) |
| virtual void | SetEdgeColor (double r, double g, double b) |
| virtual void | SetInteractiveSelectionColor (double r, double g, double b) |
| virtual void | SetInterpolation (int val) |
| virtual void | SetLineWidth (double val) |
| virtual void | SetOpacity (double val) |
| virtual void | SetEdgeOpacity (double val) |
| virtual void | SetPointSize (double val) |
| virtual void | SetSpecularColor (double r, double g, double b) |
| virtual void | SetSpecularPower (double val) |
| virtual void | SetLuminosity (double val) |
| virtual void | SetRenderPointsAsSpheres (bool) |
| virtual void | SetRenderLinesAsTubes (bool) |
| virtual void | SetRoughness (double val) |
| virtual void | SetMetallic (double val) |
| virtual void | SetEdgeTint (double r, double g, double b) |
| virtual void | SetAnisotropy (double val) |
| virtual void | SetAnisotropyRotation (double val) |
| virtual void | SetBaseIOR (double val) |
| virtual void | SetCoatIOR (double val) |
| virtual void | SetCoatStrength (double val) |
| virtual void | SetCoatRoughness (double val) |
| virtual void | SetCoatNormalScale (double val) |
| virtual void | SetCoatColor (double r, double g, double b) |
| virtual void | SetBaseColorTexture (vtkTexture *tex) |
| virtual void | SetMaterialTexture (vtkTexture *tex) |
| virtual void | SetAnisotropyTexture (vtkTexture *tex) |
| virtual void | SetNormalTexture (vtkTexture *tex) |
| virtual void | SetCoatNormalTexture (vtkTexture *tex) |
| virtual void | SetEmissiveTexture (vtkTexture *tex) |
| virtual void | SetNormalScale (double val) |
| virtual void | SetOcclusionStrength (double val) |
| virtual void | SetEmissiveFactor (double rval, double gval, double bval) |
| virtual void | SetShowTexturesOnBackface (bool) |
| virtual void | SetOrientation (double, double, double) |
| virtual void | SetOrigin (double, double, double) |
| virtual void | SetPosition (double, double, double) |
| virtual void | SetScale (double, double, double) |
| virtual void | SetTexture (vtkTexture *) |
| virtual void | SetUserTransform (const double[16]) |
| virtual void | SetCoordinateSystem (int) |
| virtual void | SetTextureTransform (vtkTransform *) |
| virtual vtkTransform * | GetTextureTransform () |
| virtual void | SetRepeatTextures (bool) |
| virtual bool | GetRepeatTextures () |
| virtual void | SetInterpolateTextures (bool) |
| virtual bool | GetInterpolateTextures () |
| virtual void | SetUseMipmapTextures (bool) |
| virtual bool | GetUseMipmapTextures () |
| virtual void | SetInterpolateScalarsBeforeMapping (int val) |
| virtual void | SetLookupTable (vtkScalarsToColors *val) |
| virtual void | SetColorMissingArraysWithNanColor (bool val) |
| virtual void | SetSeamlessU (bool) |
| virtual void | SetSeamlessV (bool) |
| virtual void | SetSelection (vtkSelection *selection) |
| Sets the selection used by the mapper. More... | |
| vtkPVLODActor * | GetActor () |
| Provides access to the actor used by this representation. More... | |
| const char * | GetColorArrayName () |
| Convenience method to get the array name used to scalar color with. More... | |
| virtual void | SetMaterial (const char *) |
| For OSPRay, choose from among available materials. More... | |
| virtual void | SetShaderReplacements (const char *) |
| Specify shader replacements using a Json string. More... | |
| void | SetArrayIdNames (const char *pointArray, const char *cellArray) override |
| Specify the array names used for the selection. More... | |
| void | SetBlockColorsDistinctValues (int distinctValues) |
| Determines the number of distinct values in vtkBlockColors See also vtkPVGeometryFilter. More... | |
| int | GetBlockColorsDistinctValues () |
| virtual void | DisableLightingOn () |
| Disables the lighting on the object. More... | |
| virtual void | DisableLightingOff () |
| virtual void | SetDisableLighting (bool) |
| virtual bool | GetDisableLighting () |
| virtual void | SetAmbient (double) |
| Set the lighting properties of the object. More... | |
| virtual void | SetDiffuse (double) |
| virtual void | SetSpecular (double) |
| virtual double | GetAmbient () |
| virtual double | GetDiffuse () |
| virtual double | GetSpecular () |
| void | SetCoordinateShiftScaleMethod (int val) |
| Set the shift scale method for the point coordinates see vtkOpenGLVertexBufferObject.h for more information. More... | |
| int | GetCoordinateShiftScaleMethod () |
| virtual int | GetRepresentation () |
| Set the representation type. More... | |
| virtual void | SetRequestGhostCellsIfNeeded (bool) |
| Representations that use geometry representation as the internal representation should turn this flag off so that we don't end up requesting ghost cells twice. More... | |
| virtual bool | GetRequestGhostCellsIfNeeded () |
| virtual void | RequestGhostCellsIfNeededOn () |
| virtual void | RequestGhostCellsIfNeededOff () |
| virtual void | SetMapScalars (int val) |
| Sets if scalars are mapped through a color-map or are used directly as colors. More... | |
| virtual void | SetStatic (int val) |
| virtual void | SetActiveAssembly (const char *) |
| Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More... | |
| virtual char * | GetActiveAssembly () |
| void | AddBlockSelector (const char *selector) |
| Update list of selectors that determine the selected blocks. More... | |
| void | RemoveAllBlockSelectors () |
| void | SetBlockColor (const char *selector, double r, double g, double b) |
| Set the color for a single block. More... | |
| void | RemoveAllBlockColors () |
| void | SetBlockOpacity (const char *selector, double opacity) |
| Set the opacity for a single block. More... | |
| void | RemoveAllBlockOpacities () |
| void | SetBlockInterpolateScalarsBeforeMapping (const char *selector, bool interpolate) |
| Set if to interpolate scalars before mapping for a single block. More... | |
| void | RemoveAllBlockInterpolateScalarsBeforeMappings () |
| void | SetBlockMapScalars (const char *selector, int val) |
| Set the block to map scalars for a single block. More... | |
| void | RemoveAllBlockMapScalars () |
| void | SetBlockArrayName (const char *selector, int assoc, const char *arrayName) |
| Set the color array for a single block. More... | |
| void | RemoveAllBlockArrayNames () |
| void | SetBlockLookupTable (vtkScalarsToColors *lut) |
| Set the look up table for a single block. More... | |
| void | RemoveAllBlockLookupTables () |
| virtual void | SetEnableScaling (int v) |
| For OSPRay controls sizing of implicit spheres (points) and cylinders (lines) More... | |
| virtual void | SetScalingArrayName (const char *) |
| virtual void | SetScalingFunction (vtkPiecewiseFunction *pwf) |
| virtual void | SetUseDataPartitions (bool) |
| Specify whether or not to redistribute the data. More... | |
| virtual bool | GetUseDataPartitions () |
| virtual void | SetUseShaderReplacements (bool) |
| Specify whether or not to shader replacements string must be used. More... | |
| virtual bool | GetUseShaderReplacements () |
| void | SetPlaceHolderDataType (int datatype) |
| Set/Get the placeholder data type. More... | |
| virtual int | GetPlaceHolderDataType () |
Public Member Functions inherited from vtkPVDataRepresentation | |
| virtual void | MarkModified () |
| This is one of the most important functions. More... | |
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| Initialize the representation with an identifier range so each internal representation can own a unique ID. More... | |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
| Returns the cache-key the representation is currently using. More... | |
| Retrieves an output port for the input data object at the specified port and connection index. More... | |
| Provides access to the view. More... | |
Returns the timestamp when RequestData was executed on the representation. More... | |
| bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More... | |
| Set the update time. More... | |
| Get whether the UpdateTime is valid. More... | |
| void | ResetUpdateTime () |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
| Making these methods public. More... | |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| This flag indicates if the representation is for a temporal pipeline. More... | |
Overridden to ensure that MarkModified is called. More... | |
Public Member Functions inherited from vtkDataRepresentation | |
Public Member Functions inherited from vtkPassInputTypeAlgorithm | |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
vtkOutlineRepresentation is merely a vtkGeometryRepresentationWithFaces that forces the geometry filter to produce outlines.
Definition at line 17 of file vtkOutlineRepresentation.h.
Definition at line 21 of file vtkOutlineRepresentation.h.
Reimplemented from vtkGeometryRepresentationWithFaces.
inlineoverridevirtual |
Accepted strings are: "Points", "Wireframe", "Surface" and "Surface With Edges".
Reimplemented from vtkGeometryRepresentation.
Definition at line 24 of file vtkOutlineRepresentation.h.
Definition at line 25 of file vtkOutlineRepresentation.h.
Definition at line 26 of file vtkOutlineRepresentation.h.
Definition at line 27 of file vtkOutlineRepresentation.h.
inlineoverrideprotectedvirtual |
This adds VTK_SURFACE_WITH_EDGES to those defined in vtkProperty.
Definition at line 33 of file vtkOutlineRepresentation.h.
1.8.13 on Sun Dec 14 2025
