provides meta data about arrays. More...
#include <vtkPVArrayInformation.h>
| void | Initialize () |
| Resets to default state. More... | |
| virtual int | GetDataType () |
| Get the type for values in the array e.g. More... | |
| const char * | GetDataTypeAsString () const |
| Returns a printable string for the array value type. More... | |
| std::string | GetRangesAsString (int lowExponent=-6, int highExponent=20) const |
| Returns range as a string. More... | |
| const char * | GetName () const |
| Get array's name. More... | |
| int | GetNumberOfComponents () const |
| Get number of components. More... | |
| const char * | GetComponentName (int component) const |
| Returns the name for a component. More... | |
| virtual vtkTypeInt64 | GetNumberOfTuples () |
| Returns the number of tuples in this array. More... | |
| void | GetDataTypeRange (double range[2]) const |
| This method return the Min and Max possible range of the native data type. More... | |
| void | CopyFromCellAttribute (vtkCellGrid *grid, vtkCellAttribute *attribute) |
| void | CopyFromGenericAttribute (vtkGenericAttribute *array) |
| void | CopyToStream (vtkClientServerStream *) const |
| bool | CopyFromStream (const vtkClientServerStream *) |
| const double * | GetComponentRange (int comp) const VTK_SIZEHINT(2) |
| Returns component range. More... | |
| void | GetComponentRange (int comp, double range[2]) const |
| const double * | GetComponentFiniteRange (int component) const VTK_SIZEHINT(2) |
| Returns the finite range for each component. More... | |
| void | GetComponentFiniteRange (int comp, double range[2]) const |
| virtual bool | GetIsPartial () |
| If IsPartial is true, this array is in only some of the parts of a multi-block dataset. More... | |
| int | GetNumberOfInformationKeys () const |
| Get information on the InformationKeys of this array. More... | |
| const char * | GetInformationKeyLocation (int) const |
| const char * | GetInformationKeyName (int) const |
| bool | HasInformationKey (const char *location, const char *name) const |
| int | GetNumberOfStringValues () |
| For string arrays, this returns first few non-empty values. More... | |
| const char * | GetStringValue (int) |
| void | CopyFromArray (vtkAbstractArray *array) |
| Copy info from an array. More... | |
| void | CopyFromArray (vtkFieldData *fieldData, int fdArrayIdx) |
| void | CopyFromArray (vtkAbstractArray *array, vtkFieldData *fieldData) |
| static vtkPVArrayInformation * | New () |
| static vtkPVArrayInformation * | SafeDownCast (vtkObject *o) |
Friends | |
| class | vtkPVDataSetAttributesInformation |
| class | vtkPVDataInformation |
vtkPVArrayInformation provides meta-data about individual arrays. It is accessed through vtkPVDataInformation and provides information like ranges, component names, etc. for array present in a dataset.
Definition at line 31 of file vtkPVArrayInformation.h.
Definition at line 35 of file vtkPVArrayInformation.h.
| void vtkPVArrayInformation::Initialize | ( | ) |
VTK_FLOAT, VTK_DOUBLE etc.
Definition at line 51 of file vtkPVArrayInformation.h.
| std::string vtkPVArrayInformation::GetRangesAsString | ( | int | lowExponent = -6, |
| int | highExponent = 20 |
| ) | const |
For string arrays, this lists string values instead.
Get array's name.
Definition at line 62 of file vtkPVArrayInformation.h.
| int vtkPVArrayInformation::GetNumberOfComponents | ( | ) | const |
If none present, a default component name may be returned.
If component is -1, then the range of the magnitude (L2 norm) over all components will be provided.
Returns invalid range for non-numeric arrays.
| void vtkPVArrayInformation::GetDataTypeRange | ( | double | range[2] | ) | const |
For example if a vtkScalars consists of unsigned char data these will return (0,255). Nothing particular for 12bits data is done
By default, IsPartial is set to 0.
| int vtkPVArrayInformation::GetNumberOfInformationKeys | ( | ) | const |
| int vtkPVArrayInformation::GetNumberOfStringValues | ( | ) |
| void vtkPVArrayInformation::CopyFromArray | ( | vtkAbstractArray * | array | ) |
Prefer the field data overload when copying from a field data array.
| void vtkPVArrayInformation::CopyFromArray | ( | vtkFieldData * | fieldData, |
| int | fdArrayIdx | ||
| void vtkPVArrayInformation::CopyFromArray | ( | vtkAbstractArray * | array, |
| vtkFieldData * | fieldData | ||
| void vtkPVArrayInformation::CopyFromCellAttribute | ( | vtkCellGrid * | grid, |
| vtkCellAttribute * | attribute | ||
| void vtkPVArrayInformation::CopyFromGenericAttribute | ( | vtkGenericAttribute * | array | ) |
| void vtkPVArrayInformation::CopyToStream | ( | vtkClientServerStream * | ) | const |
| bool vtkPVArrayInformation::CopyFromStream | ( | const vtkClientServerStream * | ) |
API for vtkPVDataSetAttributesInformation.
protectedvirtual |
protectedvirtual |
friend |
Definition at line 159 of file vtkPVArrayInformation.h.
friend |
Definition at line 160 of file vtkPVArrayInformation.h.
1.8.13 on Sun Dec 14 2025
