manager for data-delivery. More...
#include <vtkPVDataDeliveryManager.h>
| class | vtkInternals |
| int | GetSynchronizationMagicNumber () |
| Returned a hash number that can be used to verify that both client and server side are in synch representation wise for delivery. More... | |
| vtkDataObject * | GetPiece (vtkPVDataRepresentation *repr, bool low_res, int port=0) |
Returns the local data object set by calling SetPiece (or from the cache). More... | |
| vtkDataObject * | GetDeliveredPiece (vtkPVDataRepresentation *repr, bool low_res, int port=0) |
| Returns the data object post-delivery. More... | |
| void | ClearCache (vtkPVDataRepresentation *repr) |
| Clear all cached data objects for the given representation. More... | |
| unsigned long | GetVisibleDataSize (bool low_res) |
| Returns the size for all visible geometry. More... | |
| bool | NeedsDelivery (vtkMTimeType timestamp, std::vector< unsigned int > &keys_to_deliver, bool use_lod) |
| Internal method used to determine the list of representations that need their geometry delivered. More... | |
| void | Deliver (int use_low_res, unsigned int size, unsigned int *keys) |
| Triggers delivery for the geometries of indicated representations. More... | |
| virtual int | GetDeliveredDataKey (bool low_res) const |
| Views that support changing of which ranks do the rendering at runtime based on things like data sizes, etc. More... | |
| void | SetView (vtkPVView *) |
| Get/Set the render-view. More... | |
| vtkPVView * | GetView () const |
| void | RegisterRepresentation (vtkPVDataRepresentation *repr) |
| View uses these methods to register a representation with the storage. More... | |
| void | UnRegisterRepresentation (vtkPVDataRepresentation *) |
| vtkPVDataRepresentation * | GetRepresentation (unsigned int) |
| void | SetPiece (vtkPVDataRepresentation *repr, vtkDataObject *data, bool low_res, unsigned long trueSize=0, int port=0) |
| Representations (indirectly via vtkPVRenderView::SetPiece()) call this method to register the geometry type they are rendering. More... | |
| bool | HasPiece (vtkPVDataRepresentation *repr, bool low_res=false, int port=0) |
| vtkAlgorithmOutput * | GetProducer (vtkPVDataRepresentation *, bool low_res, int port=0) |
| Provides access to the producer port for the geometry of a registered representation. More... | |
| vtkInformation * | GetPieceInformation (vtkPVDataRepresentation *repr, bool low_res, int port=0) |
| Set/Get meta-data container for the specific piece. More... | |
| int | GetNumberOfPorts (vtkPVDataRepresentation *repr) |
| Returns number of known port for the representation. More... | |
| static vtkPVDataDeliveryManager * | SafeDownCast (vtkObject *o) |
| vtkPVDataDeliveryManager () | |
| ~vtkPVDataDeliveryManager () override | |
| double | GetCacheKey (vtkPVDataRepresentation *repr) const |
| virtual void | MoveData (vtkPVDataRepresentation *repr, bool low_res, int port)=0 |
| This method is called to request that the subclass do appropriate transfer for the indicated representation. More... | |
Protected Attributes | |
| vtkInternals * | Internals |
ParaView's multi-configuration / multi-process modes pose a challenge for views. At runtime, the current configuration will determine which processes have what parts of data and which processes are expected to "render" that data. While views and their representations may add certain qualifiers to this statement, generally speaking, all views have to support taking the data from the data-processing nodes and delivering it to the rendering nodes. This is where vtkPVDataDeliveryManager comes in play. It helps views (viz. vtkPVView subclasses) move the data.
Definition at line 35 of file vtkPVDataDeliveryManager.h.
Definition at line 38 of file vtkPVDataDeliveryManager.h.
Reimplemented in vtkPVRenderViewDataDeliveryManager, and vtkPVContextViewDataDeliveryManager.
Reimplemented in vtkPVRenderViewDataDeliveryManager.
| void vtkPVDataDeliveryManager::SetView | ( | vtkPVView * | ) |
The view is not reference counted.
| vtkPVView* vtkPVDataDeliveryManager::GetView | ( | ) | const |
| int vtkPVDataDeliveryManager::GetSynchronizationMagicNumber | ( | ) |
| void vtkPVDataDeliveryManager::RegisterRepresentation | ( | vtkPVDataRepresentation * | repr | ) |
This makes it possible for representations to communicate with the storage directly using a self pointer, while enables views on different processes to communicate information about representations using their unique ids.
| void vtkPVDataDeliveryManager::UnRegisterRepresentation | ( | vtkPVDataRepresentation * | ) |
| vtkPVDataRepresentation* vtkPVDataDeliveryManager::GetRepresentation | ( | unsigned | int | ) |
| void vtkPVDataDeliveryManager::SetPiece | ( | vtkPVDataRepresentation * | repr, |
| vtkDataObject * | data, | ||
| bool | low_res, | ||
| unsigned long | trueSize = 0, |
| int | port = 0 |
Every representation that requires delivering of any geometry must register with the vtkPVDataDeliveryManager and never manage the delivery on its own.
| bool vtkPVDataDeliveryManager::HasPiece | ( | vtkPVDataRepresentation * | repr, |
| bool | low_res = false, |
| int | port = 0 |
| vtkDataObject* vtkPVDataDeliveryManager::GetPiece | ( | vtkPVDataRepresentation * | repr, |
| int | port = 0 |
This is the data object pre-delivery.
| vtkDataObject* vtkPVDataDeliveryManager::GetDeliveredPiece | ( | vtkPVDataRepresentation * | repr, |
| int | port = 0 |
| void vtkPVDataDeliveryManager::ClearCache | ( | vtkPVDataRepresentation * | repr | ) |
| vtkAlgorithmOutput* vtkPVDataDeliveryManager::GetProducer | ( | vtkPVDataRepresentation * | , |
| int | port = 0 |
Representations use these methods (indirectly via vtkPVRenderView::GetPieceProducer() and GetPieceProducerLOD()) to obtain the geometry producer for the geometry to be rendered.
| vtkInformation* vtkPVDataDeliveryManager::GetPieceInformation | ( | vtkPVDataRepresentation * | repr, |
| int | port = 0 |
Views can use it to store arbitrary metadata for each piece.
| int vtkPVDataDeliveryManager::GetNumberOfPorts | ( | vtkPVDataRepresentation * | repr | ) |
| unsigned long vtkPVDataDeliveryManager::GetVisibleDataSize | ( | bool | low_res | ) |
If low_res is true, and low-res data is not available for a particular representation, then it's high-res data size will be used assuming that the representation is going to render the high-res geometry for low-res rendering as well.
| bool vtkPVDataDeliveryManager::NeedsDelivery | ( | vtkMTimeType | timestamp, |
| std::vector< unsigned int > & | keys_to_deliver, | ||
| bool | use_lod | ||
This is done on the "client" side, with the client decide what geometries it needs and then requests those from the server-sides using Deliver().
inlinevirtual |
may override this method to provide a unique key for each different mode. This makes it possible to keep delivered data object for each mode separate and thus avoid transfers if the mode is changed on the fly.
Default implementation simply returns 0.
Definition at line 154 of file vtkPVDataDeliveryManager.h.
protectedpure virtual |
Implemented in vtkPVRenderViewDataDeliveryManager, and vtkPVContextViewDataDeliveryManager.
Definition at line 172 of file vtkPVDataDeliveryManager.h.
1.8.13 on Sat Dec 13 2025
