Information object that can be used to obtain information about a file/directory. More...
#include <vtkPVFileInformation.h>
| enum | FileTypes { INVALID = 0, SINGLE_FILE, SINGLE_FILE_LINK, DIRECTORY, DIRECTORY_LINK, FILE_GROUP, DRIVE, NETWORK_ROOT, NETWORK_DOMAIN, NETWORK_SERVER, NETWORK_SHARE, DIRECTORY_GROUP } |
| typedef vtkPVInformation | Superclass |
Public Types inherited from vtkPVInformation | |
| void | CopyFromObject (vtkObject *object) override |
| Transfer information about a single object into this object. More... | |
| void | Initialize () |
| Initializes the information object. More... | |
| void | FetchDirectoryListing () |
| Fetch the directory listing to be able to use GetSize or GetContents with directories. More... | |
| void | CopyToStream (vtkClientServerStream *) override |
| Manage a serialized version of the information. More... | |
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual char * | GetName () |
| Get the name of the file/directory whose information is represented by this object. More... | |
| virtual char * | GetFullPath () |
| Get the full path of the file/directory whose information is represented by this object. More... | |
| virtual int | GetType () |
| Get the type of this file object. More... | |
| virtual bool | GetHidden () |
| Get the state of the hidden flag for the file/directory. More... | |
| virtual bool | GetGroupFileSequences () |
| Groups file sequences when found. More... | |
| virtual void | SetGroupFileSequences (bool) |
| virtual void | GroupFileSequencesOn () |
| virtual void | GroupFileSequencesOff () |
| virtual vtkCollection * | GetContents () |
| Get the Contents for this directory. More... | |
| virtual char * | GetExtension () |
| virtual long long | GetSize () |
| virtual time_t | GetModificationTime () |
Public Member Functions inherited from vtkPVInformation | |
| virtual void | AddInformation (vtkPVInformation *) |
| Merge another information object. More... | |
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| Serialize/Deserialize the parameters that control how/what information is gathered. More... | |
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More... | |
| static vtkPVFileInformation * | New () |
| static vtkPVFileInformation * | SafeDownCast (vtkObject *o) |
| static std::string | GetParaViewSharedResourcesDirectory () |
| Returns the path to the base data directory path holding various files packaged with ParaView. More... | |
| static std::string | GetParaViewExampleFilesDirectory () |
| Return the path of the example data packaged with ParaView. More... | |
| static std::string | GetParaViewDocDirectory () |
| Return the path of the documents packaged with ParaView. More... | |
| static std::string | GetParaViewTranslationsDirectory () |
| Return the path of the translations packaged with ParaView. More... | |
Static Public Member Functions inherited from vtkPVInformation | |
| static vtkPVInformation * | SafeDownCast (vtkObject *o) |
Protected Attributes | |
| vtkCollection * | Contents |
| vtkFileSequenceParser * | SequenceParser |
| char * | Name |
| char * | FullPath |
| int | Type |
| bool | Hidden |
| char * | Extension |
| long long | Size |
| time_t | ModificationTime |
| int | FastFileTypeDetection |
| bool | ReadDetailedFileInformation |
| bool | GroupFileSequences |
| bool | IncludeExamples |
Protected Attributes inherited from vtkPVInformation | |
| int | RootOnly |
| static bool | IsDirectory (int t) |
| Helper that returns whether a FileType is a directory (DIRECTORY, DRIVE, NETWORK_ROOT, etc...) Or in other words, a type that we can do a DirectoryListing on. More... | |
| bool | IsDirectory () const |
| static bool | IsGroup (int type) |
| Helper that returns true if file-type is a network related file i.e. More... | |
| bool | IsGroup () const |
vtkPVFileInformation can be used to collect information about file or directory. vtkPVFileInformation can collect information from a vtkPVFileInformationHelper object alone.
Definition at line 27 of file vtkPVFileInformation.h.
Definition at line 31 of file vtkPVFileInformation.h.
| Enumerator | |
| INVALID | |
| SINGLE_FILE | |
| SINGLE_FILE_LINK | |
| DIRECTORY | |
| DIRECTORY_LINK | |
| FILE_GROUP | |
| DRIVE | |
| NETWORK_ROOT | |
| NETWORK_DOMAIN | |
| NETWORK_SERVER | |
| NETWORK_SHARE | |
| DIRECTORY_GROUP | |
Definition at line 48 of file vtkPVFileInformation.h.
Reimplemented from vtkPVInformation.
The object must be a vtkPVFileInformationHelper.
Implements vtkPVInformation.
Definition at line 71 of file vtkPVFileInformation.h.
inlinestatic |
either a FILE_GROUP or a DIRECTORY_GROUP.
Definition at line 79 of file vtkPVFileInformation.h.
Definition at line 90 of file vtkPVFileInformation.h.
| void vtkPVFileInformation::Initialize | ( | ) |
A file sequence could be [foo1.png, foo2.png, foo6.png]. When turned on, the series of files is grouped and our sequence example is named foo..png and original files are discarded from the listing. By default, this flag is set to true.
Returns a collection with vtkPVFileInformation objects for the contents of this directory if Type == DIRECTORY or the contents of this file group if Type == FILE_GROUP or the contents of this directory group if Type == DIRECTORY_GROUP.
| void vtkPVFileInformation::FetchDirectoryListing | ( | ) |
protectedvirtual |
protectedvirtual |
protectedvirtual |
Definition at line 184 of file vtkPVFileInformation.h.
Definition at line 185 of file vtkPVFileInformation.h.
Definition at line 187 of file vtkPVFileInformation.h.
Definition at line 188 of file vtkPVFileInformation.h.
Definition at line 189 of file vtkPVFileInformation.h.
Definition at line 190 of file vtkPVFileInformation.h.
Definition at line 191 of file vtkPVFileInformation.h.
Definition at line 192 of file vtkPVFileInformation.h.
Definition at line 193 of file vtkPVFileInformation.h.
Definition at line 209 of file vtkPVFileInformation.h.
Definition at line 210 of file vtkPVFileInformation.h.
Definition at line 211 of file vtkPVFileInformation.h.
Definition at line 212 of file vtkPVFileInformation.h.
1.8.13 on Sun Dec 14 2025
