vtkPVMultiClientsInformation Class Reference
Gets Multi-clients information from the server. More...
#include <vtkPVMultiClientsInformation.h>
Inheritance diagram for vtkPVMultiClientsInformation:
Collaboration diagram for vtkPVMultiClientsInformation:
typedef vtkPVInformation Superclass
- Public Types inherited from vtkPVInformation
void DeepCopy (vtkPVMultiClientsInformation *info)
void CopyFromObject (vtkObject *) override
 Transfer information about a single object into this object. More...
void AddInformation (vtkPVInformation *) override
 Merge another information object. More...
int GetClientId (int idx)
 Return the client id of the nth connected client. More...
void CopyToStream (vtkClientServerStream *) override
 Manage a serialized version of the information. More...
void CopyFromStream (const vtkClientServerStream *) override
virtual int GetClientId ()
 Get the id that correspond to the current client. More...
virtual int GetNumberOfClients ()
 Return the number of connected clients. More...
virtual int GetMultiClientEnable ()
 Return 1 if the server allow server client to connect to itself. More...
virtual int GetMasterId ()
 Return the Id of the client that has been elected as master. More...
- Public Member Functions inherited from vtkPVInformation
virtual void CopyParametersToStream (vtkMultiProcessStream &)
 Serialize/Deserialize the parameters that control how/what information is gathered. More...
virtual void CopyParametersFromStream (vtkMultiProcessStream &)
virtual int GetRootOnly ()
 Set/get whether to gather information only from the root. More...
static vtkPVMultiClientsInformationNew ()
static vtkPVMultiClientsInformationSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVInformation
static vtkPVInformationSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVMultiClientsInformation ()
 ~vtkPVMultiClientsInformation () override
 vtkPVMultiClientsInformation (const vtkPVMultiClientsInformation &)=delete
void operator= (const vtkPVMultiClientsInformation &)=delete
- Protected Member Functions inherited from vtkPVInformation
 vtkPVInformation ()
 ~vtkPVInformation () override
virtual void SetRootOnly (int)
 vtkPVInformation (const vtkPVInformation &)=delete
void operator= (const vtkPVInformation &)=delete
int ClientId
intClientIds
int NumberOfClients
int MultiClientEnable
int MasterId
- Protected Attributes inherited from vtkPVInformation
int RootOnly
This objects is used by the client to get the number of multi-clients server as well as their ids.
Definition at line 19 of file vtkPVMultiClientsInformation.h.
Definition at line 23 of file vtkPVMultiClientsInformation.h.
◆ vtkPVMultiClientsInformation() [1/2]
vtkPVMultiClientsInformation::vtkPVMultiClientsInformation ( )
◆ ~vtkPVMultiClientsInformation()
vtkPVMultiClientsInformation::~vtkPVMultiClientsInformation ( )
◆ vtkPVMultiClientsInformation() [2/2]
vtkPVMultiClientsInformation::vtkPVMultiClientsInformation ( const vtkPVMultiClientsInformation )
protecteddelete
static vtkPVMultiClientsInformation* vtkPVMultiClientsInformation::New ( )
virtual const char* vtkPVMultiClientsInformation::GetClassName ( )
Reimplemented from vtkPVInformation.
static int vtkPVMultiClientsInformation::IsTypeOf ( const char *  type)
virtual int vtkPVMultiClientsInformation::IsA ( const char *  type)
static vtkPVMultiClientsInformation* vtkPVMultiClientsInformation::SafeDownCast ( vtkObject o)
void vtkPVMultiClientsInformation::PrintSelf ( ostream &  os,
◆ DeepCopy()
void vtkPVMultiClientsInformation::DeepCopy ( vtkPVMultiClientsInformation info)
◆ CopyFromObject()
void vtkPVMultiClientsInformation::CopyFromObject ( vtkObject )
◆ AddInformation()
void vtkPVMultiClientsInformation::AddInformation ( vtkPVInformation )
◆ CopyToStream()
void vtkPVMultiClientsInformation::CopyToStream ( vtkClientServerStream )
Implements vtkPVInformation.
◆ CopyFromStream()
void vtkPVMultiClientsInformation::CopyFromStream ( const vtkClientServerStream )
◆ GetClientId() [1/2]
virtual int vtkPVMultiClientsInformation::GetClientId ( )
◆ GetClientId() [2/2]
int vtkPVMultiClientsInformation::GetClientId ( int  idx)
idx < NumberOfClients
◆ GetNumberOfClients()
virtual int vtkPVMultiClientsInformation::GetNumberOfClients ( )
◆ GetMultiClientEnable()
virtual int vtkPVMultiClientsInformation::GetMultiClientEnable ( )
◆ GetMasterId()
virtual int vtkPVMultiClientsInformation::GetMasterId ( )
◆ operator=()
void vtkPVMultiClientsInformation::operator= ( const vtkPVMultiClientsInformation )
protecteddelete
◆ ClientId
int vtkPVMultiClientsInformation::ClientId
Definition at line 84 of file vtkPVMultiClientsInformation.h.
◆ ClientIds
int* vtkPVMultiClientsInformation::ClientIds
Definition at line 85 of file vtkPVMultiClientsInformation.h.
◆ NumberOfClients
int vtkPVMultiClientsInformation::NumberOfClients
Definition at line 86 of file vtkPVMultiClientsInformation.h.
◆ MultiClientEnable
int vtkPVMultiClientsInformation::MultiClientEnable
Definition at line 87 of file vtkPVMultiClientsInformation.h.
◆ MasterId
int vtkPVMultiClientsInformation::MasterId
Definition at line 88 of file vtkPVMultiClientsInformation.h.
