a global manager for each processes to keep track of plugins loaded on that process. More...
#include <vtkPVPluginTracker.h>
| enum | { RegisterAvailablePluginEvent = vtkCommand::UserEvent + 91 } |
| void | RegisterPlugin (vtkPVPlugin *) |
| Called by vtkPVPluginLoader after a plugin is loaded on the process. More... | |
| unsigned int | RegisterAvailablePlugin (const char *filename) |
| This API is used to register available plugins without actually loading them. More... | |
| unsigned int | GetNumberOfPlugins () |
| Methods to iterate over registered plugins. More... | |
| vtkPVPlugin * | GetPlugin (unsigned int index) |
| Returns the plugin instance. More... | |
| void | LoadPluginConfigurationXMLs (const char *appname) |
| Called to load application-specific configuration xml. More... | |
| void | LoadPluginConfigurationXML (const char *filename, bool forceLoad=false) |
| void | LoadPluginConfigurationXML (vtkPVXMLElement *, bool forceLoad=false) |
| void | LoadPluginConfigurationXMLFromString (const char *xmlcontents, bool forceLoad=false) |
| const char * | GetPluginName (unsigned int index) |
| This is provided for wrapped languages since they can't directly access the vtkPVPlugin instance. More... | |
| const char * | GetPluginFileName (unsigned int index) |
| bool | GetPluginLoaded (unsigned int index) |
| bool | GetPluginAutoLoad (unsigned int index) |
| bool | GetPluginDelayedLoad (unsigned int index) |
| std::vector< std::string > | GetPluginXMLs (unsigned int index) |
| std::string | GetPluginVersion (unsigned int index) |
| std::string | GetPluginDescription (unsigned int index) |
| static vtkPVPluginTracker * | New () |
| static vtkPVPluginTracker * | SafeDownCast (vtkObject *o) |
| static vtkPVPluginTracker * | GetInstance () |
| Provides access to the singleton. More... | |
| static void | RegisterStaticPluginSearchFunction (vtkPluginSearchFunction function) |
| Sets the function used to load static plugins. More... | |
| static void | RegisterStaticPluginListFunction (vtkPluginListFunction function) |
| vtkPVPluginTracker () | |
| ~vtkPVPluginTracker () override | |
vtkPVPluginTracker is a singleton that's present on each process to keep track of plugins loaded on that process. Whenever is plugin is loaded (either statically using PV_PLUGIN_IMPORT() or dynamically, it gets registered with the on every process that it is loaded. Whenever a plugin is registered, this class fires a vtkCommand::RegisterEvent that handlers can listen to, to process the plugin.
Definition at line 33 of file vtkPVPluginTracker.h.
Definition at line 37 of file vtkPVPluginTracker.h.
| anonymous enum |
| Enumerator | |
| RegisterAvailablePluginEvent | |
Definition at line 127 of file vtkPVPluginTracker.h.
This will create the vtkPVPluginTracker singleton the first time this method is called.
| void vtkPVPluginTracker::RegisterPlugin | ( | vtkPVPlugin * | ) |
This registers the plugin instance with the manager. It fires an event (vtkCommand::RegisterEvent) signalling that a plugin was loaded. Handlers that the process the plugin by detecting the interfaces implemented by the plugin and the processing those on a case-by-case basis. Note there's no call to unregister a plugin. Once a plugin has been loaded, it cannot be unloaded for the lifetime of the process.
This fires vtkPVPluginTracker::RegisterAvailablePluginEvent to notify a new plugin has been made available.
| void vtkPVPluginTracker::LoadPluginConfigurationXMLs | ( | const char * | appname | ) |
The xml is of the form:
This method will process the XML, locate the plugin shared library, register it with all its properties and then load it or not based on the status of the auto_load flag. auto_load flag is optional and is 0 by default. filename is also optional, if not provided this method will look in different place to find the plugin, eg. paraview lib dir. It will NOT look in PV_PLUGIN_PATH.
| void vtkPVPluginTracker::LoadPluginConfigurationXML | ( | const char * | filename, |
| bool | forceLoad = false |
| void vtkPVPluginTracker::LoadPluginConfigurationXML | ( | vtkPVXMLElement * | , |
| void vtkPVPluginTracker::LoadPluginConfigurationXMLFromString | ( | const char * | xmlcontents, |
| unsigned int vtkPVPluginTracker::GetNumberOfPlugins | ( | ) |
| vtkPVPlugin* vtkPVPluginTracker::GetPlugin | ( | unsigned int | index | ) |
This is non-null only for loaded plugins. If a plugin was merely registered as a "available" plugin, then one can only use the methods to query some primitive information about that plugin.
This is also used by vtkPluginsInformation to copy plugins information.
| bool vtkPVPluginTracker::GetPluginLoaded | ( | unsigned int | index | ) |
| bool vtkPVPluginTracker::GetPluginAutoLoad | ( | unsigned int | index | ) |
| bool vtkPVPluginTracker::GetPluginDelayedLoad | ( | unsigned int | index | ) |
| std::vector<std::string> vtkPVPluginTracker::GetPluginXMLs | ( | unsigned int | index | ) |
| std::string vtkPVPluginTracker::GetPluginVersion | ( | unsigned int | index | ) |
| std::string vtkPVPluginTracker::GetPluginDescription | ( | unsigned int | index | ) |
1.8.13 on Sun Dec 14 2025
