void | DeepCopy (vtkPVPythonInformation *info) |
void | CopyFromObject (vtkObject *) override |
| Transfer information about a single object into this object. More...
void | AddInformation (vtkPVInformation *) override |
| Same as DeepCopy for this object. More...
void | CopyToStream (vtkClientServerStream *) override |
| Manage a serialized version of the information. More...
void | CopyFromStream (const vtkClientServerStream *) override |
virtual void | SetPythonSupport (bool) |
| Whether the server was compiled with python support. More...
virtual bool | GetPythonSupport () |
virtual void | PythonSupportOn () |
virtual void | PythonSupportOff () |
void | SetPythonVersion (const std::string &arg) |
| If GetPythonSupport() is true, returns the version of python detected on the server. More...
const std::string & | GetPythonVersion () |
void | SetPythonPath (const std::string &arg) |
| If GetPythonSupport() is true, returns the path to the python libraries detected on the server. More...
const std::string & | GetPythonPath () |
virtual void | SetNumpySupport (bool) |
| Whether the numpy module is available on the server. More...
virtual bool | GetNumpySupport () |
virtual void | NumpySupportOn () |
virtual void | NumpySupportOff () |
void | SetNumpyVersion (const std::string &arg) |
| If GetNumpySupport() is true, returns the version of numpy detected on the server. More...
const std::string & | GetNumpyVersion () |
void | SetNumpyPath (const std::string &arg) |
| If GetNumpySupport() is true, returns the path to numpy detected on the server. More...
const std::string & | GetNumpyPath () |
virtual void | SetMatplotlibSupport (bool) |
| Whether the matplotlib module is available on the server. More...
virtual bool | GetMatplotlibSupport () |
virtual void | MatplotlibSupportOn () |
virtual void | MatplotlibSupportOff () |
void | SetMatplotlibVersion (const std::string &arg) |
| If GetMatplotlibSupport() is true, returns the version of matplotlib detected on the server. More...
const std::string & | GetMatplotlibVersion () |
void | SetMatplotlibPath (const std::string &arg) |
| If GetMatplotlibSupport() is true, returns the path to matplotlib detected on the server. More...
const std::string & | GetMatplotlibPath () |
virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| Serialize/Deserialize the parameters that control how/what information is gathered. More...
virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More...
virtual void | Modified () |
