singleton used to keep track of options for vtkPVRenderView. More...
#include <vtkPVRenderViewSettings.h>
| enum | { DO_NOTHING = 0, OFFSET_FACES = 1, OFFSET_LINES_AND_VERTS = 2, ZSHIFT = 3 } |
| enum | { AUTOMATIC = 0, ALWAYS_2D = 1, ALWAYS_3D = 2 } |
| void | SetResolveCoincidentTopology (int mode) |
| vtkMapper settings. More... | |
| void | SetPolygonOffsetParameters (double factor, double units) |
| void | SetLineOffsetParameters (double factor, double units) |
| void | SetPointOffsetParameter (double units) |
| void | SetZShift (double a) |
| virtual void | SetOutlineThreshold (vtkIdType) |
| Set the number of cells (in millions) when the representations show try to use outline by default. More... | |
| virtual vtkIdType | GetOutlineThreshold () |
| virtual void | SetTwoSidedLighting (bool) |
| When rendering a volume, this option simulates light coming from both its direction and its opposite for all lights in the scene. More... | |
| virtual bool | GetTwoSidedLighting () |
| virtual void | SetDefaultInteractionMode (int) |
| Set the default interaction mode. More... | |
| virtual int | GetDefaultInteractionMode () |
| virtual void | SetPointPickingRadius (int) |
| Set the radius in pixels to include for finding the closet point when selecting a point on render view. More... | |
| virtual int | GetPointPickingRadius () |
| virtual void | SetDisableIceT (bool) |
| EXPERIMENTAL: Add ability to disable IceT. More... | |
| virtual bool | GetDisableIceT () |
| virtual void | SetEnableFastPreselection (bool) |
| Enable fast preselection. More... | |
| virtual bool | GetEnableFastPreselection () |
| virtual void | SetGrowSelectionRemoveSeed (bool) |
| When enabled and growing selection, remove the initial selection seed. More... | |
| virtual bool | GetGrowSelectionRemoveSeed () |
| virtual void | SetGrowSelectionRemoveIntermediateLayers (bool) |
| When enabled and growing selection, remove the intermediate layers. More... | |
| virtual bool | GetGrowSelectionRemoveIntermediateLayers () |
| virtual void | SetBackgroundColor (double, double, double) |
| Used by vtkPVRenderView and other views to determine background color. More... | |
| virtual void | SetBackgroundColor (double [3]) |
| virtual double * | GetBackgroundColor () |
| virtual void | GetBackgroundColor (double &, double &, double &) |
| virtual void | GetBackgroundColor (double [3]) |
| virtual void | SetBackground2Color (double, double, double) |
| virtual void | SetBackground2Color (double [3]) |
| virtual double * | GetBackground2Color () |
| virtual void | GetBackground2Color (double &, double &, double &) |
| virtual void | GetBackground2Color (double [3]) |
| virtual void | SetBackgroundColorMode (int) |
| virtual int | GetBackgroundColorMode () |
| virtual void | SetZoomClosestOffsetRatio (double) |
| OffsetRatio is used to add a zoom offset when using Reset Camera Closest and Zoom Closest To Data. More... | |
| virtual double | GetZoomClosestOffsetRatio () |
| static vtkPVRenderViewSettings * | New () |
| static vtkPVRenderViewSettings * | SafeDownCast (vtkObject *o) |
| static vtkPVRenderViewSettings * | GetInstance () |
| Access the singleton. More... | |
| vtkPVRenderViewSettings () | |
| ~vtkPVRenderViewSettings () override | |
Protected Attributes | |
| int | DefaultInteractionMode |
| vtkIdType | OutlineThreshold |
| bool | TwoSidedLighting = true |
| int | PointPickingRadius |
| bool | DisableIceT |
| bool | EnableFastPreselection |
| bool | GrowSelectionRemoveSeed = false |
| bool | GrowSelectionRemoveIntermediateLayers = false |
| double | BackgroundColor [3] |
| double | Background2Color [3] |
| int | BackgroundColorMode |
| double | ZoomClosestOffsetRatio |
vtkPVRenderViewSettings is a singleton used to keep track of selections for various configurable parameters used by vtkPVRenderView. All class to vtkPVRenderViewSettings::New() returns a reference to the singleton instance.
Definition at line 21 of file vtkPVRenderViewSettings.h.
Definition at line 25 of file vtkPVRenderViewSettings.h.
| anonymous enum |
| Enumerator | |
| DO_NOTHING | |
| OFFSET_FACES | |
| OFFSET_LINES_AND_VERTS | |
| ZSHIFT | |
Definition at line 33 of file vtkPVRenderViewSettings.h.
| anonymous enum |
| Enumerator | |
| AUTOMATIC | |
| ALWAYS_2D | |
| ALWAYS_3D | |
Definition at line 70 of file vtkPVRenderViewSettings.h.
vtkMapper settings.
vtkMapper settings.
It is enabled by default.
This only after single point selections i.e. when selecting a regions this radius is not respected.
When enabled, the preselection is computed using the visible geometry. This avoids a call to the extract selection filter each time the mouse moves, improving a lot the preselection highlight display, especially for big datasets.
Default is false.
Default is false.
Default is false.
Default is false.
Default is 0.9.
Default is 0.9.
Definition at line 158 of file vtkPVRenderViewSettings.h.
Definition at line 159 of file vtkPVRenderViewSettings.h.
Definition at line 160 of file vtkPVRenderViewSettings.h.
Definition at line 161 of file vtkPVRenderViewSettings.h.
Definition at line 162 of file vtkPVRenderViewSettings.h.
Definition at line 163 of file vtkPVRenderViewSettings.h.
Definition at line 164 of file vtkPVRenderViewSettings.h.
Definition at line 165 of file vtkPVRenderViewSettings.h.
Definition at line 167 of file vtkPVRenderViewSettings.h.
Definition at line 168 of file vtkPVRenderViewSettings.h.
Definition at line 169 of file vtkPVRenderViewSettings.h.
Definition at line 170 of file vtkPVRenderViewSettings.h.
1.8.13 on Sun Dec 14 2025
