vtkPropertyDecorator hold the logic of pqPropertyDecorator TODO provides a mechanism to decorate pqProperty instances to add logic to the widget to add additional control logic. More...
#include <vtkPropertyDecorator.h>
| enum | { VisibilityChangedEvent = vtkCommand::UserEvent + 1000, EnableStateChangedEvent = vtkCommand::UserEvent + 1001 } |
| This event is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
| virtual void | Initialize (vtkPVXMLElement *xml, vtkSMProxy *proxy) |
| Constructor. More... | |
| virtual bool | CanShow (bool show_advanced) const |
| Override this method to override the visibility of the widget in the panel. More... | |
| virtual bool | Enable () const |
| Override this method to override the enable state of the widget in the panel. More... | |
| static vtkPropertyDecorator * | New () |
| static vtkPropertyDecorator * | SafeDownCast (vtkObject *o) |
| static vtkSmartPointer< vtkPropertyDecorator > | Create (vtkPVXMLElement *xml, vtkSMProxy *proxy) |
| Creates a new decorator, given the xml config and the proxy containing the property For unsupported/unknown, implementations should simply return nullptr without raising any errors (or messages). More... | |
| vtkPropertyDecorator () | |
| ~vtkPropertyDecorator () override | |
| vtkPVXMLElement * | XML () const |
| vtkSMProxy * | Proxy () const |
| void | InvokeVisibilityChangedEvent () |
| void | InvokeEnableStateChangedEvent () |
Subclasses can be used to logic to control when the widget is enabled/disabled, hidden/visible, etc. based on values of other properties of UI elements.
Definition at line 29 of file vtkPropertyDecorator.h.
Definition at line 34 of file vtkPropertyDecorator.h.
| anonymous enum |
| Enumerator | |
| VisibilityChangedEvent | |
| EnableStateChangedEvent | |
Definition at line 77 of file vtkPropertyDecorator.h.
Reimplemented in vtkCompositePropertyDecorator, vtkGenericPropertyDecorator, vtkSessionTypeDecorator, vtkInputDataTypeDecorator, vtkBoolPropertyDecorator, vtkShowDecorator, vtkMultiComponentsDecorator, vtkEnableDecorator, and vtkOSPRayHidingDecorator.
Reimplemented in vtkSessionTypeDecorator, and vtkShowDecorator.
Constructor.
| xml | The XML element from the <Hints/> section for the proxy/property that resulted in the creation of the decorator. Decorators can be provided configuration parameters from the XML. |
| proxy | The proxy that owns the property of this decorator |
Reimplemented in vtkCompositePropertyDecorator, vtkGenericPropertyDecorator, vtkSessionTypeDecorator, vtkBoolPropertyDecorator, vtkInputDataTypeDecorator, vtkShowDecorator, vtkMultiComponentsDecorator, and vtkEnableDecorator.
inlinevirtual |
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget invisible given the current state.
Reimplemented in vtkCompositePropertyDecorator, vtkGenericPropertyDecorator, vtkSessionTypeDecorator, vtkInputDataTypeDecorator, vtkMultiComponentsDecorator, vtkShowDecorator, and vtkOSPRayHidingDecorator.
Definition at line 56 of file vtkPropertyDecorator.h.
inlinevirtual |
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget disabled given the current state.
Reimplemented in vtkCompositePropertyDecorator, vtkGenericPropertyDecorator, vtkSessionTypeDecorator, vtkInputDataTypeDecorator, and vtkEnableDecorator.
Definition at line 70 of file vtkPropertyDecorator.h.
Supported types are:
EnableWidgetDecorator : vtkEnableWidgetDecorator ShowWidgetDecorator : vtkShowWidgetDecorator InputDataTypeDecorator : vtkInputDataTypeDecorator GenericDecorator: vtkGenericPropertyWidgetDecorator OSPRayHidingDecorator: vtkOSPRayHidingDecorator MultiComponentsDecorator: vtkMultiComponentsDecorator CompositeDecorator: vtkCompositePropertyWidgetDecorator SessionTypeDecorator: vtkSessionTypeDecorator
1.8.13 on Sun Dec 14 2025
