Object that managed multi-client communication and provide the group awareness.
void | Push (vtkSMMessage *msg) override |
| Push a new state to the underneath implementation The provided implementation just store the message and return it at the Pull one. More...
void | Pull (vtkSMMessage *msg) override |
| Pull the current state of the underneath implementation The provided implementation update the given message with the one that has been previously pushed. More...
virtual void | AboutToDelete () |
| This method is called before the deletion of the SIObject. More...
virtual void | Initialize (vtkPVSessionCore *session) |
| Initializes the instance. More...
vtkClientServerInterpreter * | GetInterpreter () |
| Provides access to the Interpreter. More...
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) const |
| Convenience method to obtain a vtkSIObject subclass given its global id. More...
vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| Convenience method to obtain a vtkObject subclass given its global id. More...
virtual void | SetGlobalID (vtkTypeUInt32) |
| Get/Set the global id for this object. More...
virtual void | Modified () |
Definition at line 16 of file vtkSICollaborationManager.h.
