creates a link between two cameras. More...
#include <vtkSMCameraLink.h>
typedef vtkSMProxyLink | Superclass |
enum | ExceptionListBehavior : int { BLACKLIST = 0, WHITELIST } |
typedef vtkSMLink | Superclass |
enum | UpdateDirections { NONE = 0, INPUT = 1, OUTPUT = 2 } |
typedef vtkSMRemoteObject | Superclass |
void | AddLinkedProxy (vtkSMProxy *proxy, int updateDir) override |
Add a property to the link. More... | |
void | RemoveLinkedProxy (vtkSMProxy *proxy) override |
Remove a linked proxy. More... | |
virtual void | UpdateViews (vtkSMProxy *caller, bool interactive) |
Update all the views linked with an OUTPUT direction. More... | |
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
virtual void | SetSynchronizeInteractiveRenders (int) |
Get/Set if the link should synchronize interactive renders as well. More... | |
virtual int | GetSynchronizeInteractiveRenders () |
virtual void | SynchronizeInteractiveRendersOn () |
virtual void | SynchronizeInteractiveRendersOff () |
virtual void | LinkProxies (vtkSMProxy *proxy1, vtkSMProxy *proxy2) |
Utility method to add 2 proxies, both as INPUT and OUTPUT. More... | |
virtual void | LinkProxyPropertyProxies (vtkSMProxy *proxy1, vtkSMProxy *proxy2, const char *pname) |
Utility method to link the proxies stored as proxy property of input proxies. More... | |
vtkSMProxy * | GetLinkedProxy (int index) override |
Get a proxy involved in this link. More... | |
void | RemoveAllLinks () override |
Remove all links. More... | |
unsigned int | GetNumberOfLinkedObjects () override |
Get the number of proxies that are involved in this link. More... | |
unsigned int | GetNumberOfLinkedProxies () |
int | GetLinkedObjectDirection (int index) override |
Get the direction of a proxy involved in this link (see vtkSMLink::UpdateDirections) More... | |
int | GetLinkedProxyDirection (int index) |
void | AddException (const char *propertyname) |
It is possible to exclude certain properties from being synchronized by this link. More... | |
void | RemoveException (const char *propertyname) |
void | ClearExceptions () |
virtual void | SetExceptionBehavior (int) |
Set/Get exception behavior. More... | |
virtual int | GetExceptionBehavior () |
void | SetExceptionBehaviorToBlacklist () |
void | SetExceptionBehaviorToWhitelist () |
This method returns the full object state that can be used to create the object from scratch. More... | |
virtual void | SetPropagateUpdateVTKObjects (int) |
This flag determines if UpdateVTKObjects calls are to be propagated. More... | |
virtual int | GetPropagateUpdateVTKObjects () |
virtual void | PropagateUpdateVTKObjectsOn () |
virtual void | PropagateUpdateVTKObjectsOff () |
virtual void | SetEnabled (bool) |
Get/Set if the link is enabled. More... | |
virtual bool | GetEnabled () |
Override the SetSession so if the object already have an ID we automatically register it to the associated session. More... | |
bool | HasGlobalID () |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it. More... | |
virtual void | EnableLocalPushOnly () |
Allow to switch off any push of state change to the server for that particular object. More... | |
virtual void | DisableLocalPushOnly () |
Enable the given remote object to communicate its state normally to the server location. More... | |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast. More... | |
virtual void | SetLocation (vtkTypeUInt32) |
Get/Set the location where the underlying VTK-objects are created. More... | |
Get the global unique id for this object. More... | |
virtual void | PrototypeOn () |
Allow user to set the remote object to be discard for Undo/Redo action. More... | |
virtual void | PrototypeOff () |
bool | IsPrototype () |
virtual void | SetPrototype (bool) |
virtual void | Modified () |
static vtkSMCameraLink * | New () |
static vtkSMCameraLink * | SafeDownCast (vtkObject *o) |
static std::set< std::pair< std::string, std::string > > | CameraProperties () |
Get the list of camera properties to link. More... | |
static vtkSMProxyLink * | New () |
static vtkSMProxyLink * | SafeDownCast (vtkObject *o) |
static vtkSMLink * | SafeDownCast (vtkObject *o) |
static vtkSMRemoteObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMCameraLink () | |
~vtkSMCameraLink () override | |
void | UpdateVTKObjects (vtkSMProxy *proxy) override |
Called when an input proxy is updated (UpdateVTKObjects). More... | |
void | PropertyModified (vtkSMProxy *proxy, const char *pname) override |
Called when a property of an input proxy is modified. More... | |
void | UpdateProperty (vtkSMProxy *, const char *) override |
Called when a property is pushed. More... | |
std::string | GetXMLTagName () override |
Override to ajust to this class name. More... | |
void | CopyProperties (vtkSMProxy *caller) |
Internal method to copy vtkSMproperty values from caller to all linked proxies. More... | |
void | ResetCamera (vtkObject *caller) |
void | UpdateState () override |
Update the internal protobuf state. More... | |
vtkSMProxyLink () | |
~vtkSMProxyLink () override | |
void | SaveXMLState (const char *linkname, vtkPVXMLElement *parent) override |
Save the state of the link. More... | |
int | LoadXMLState (vtkPVXMLElement *linkElement, vtkSMProxyLocator *locator) override |
Load the link state. More... | |
vtkSMLink () | |
~vtkSMLink () override | |
void | PushStateToSession () |
When the state has changed we call that method so the state can be shared if any collaboration is involved. More... | |
void | ObserveProxyUpdates (vtkSMProxy *proxy) |
Subclasses call this method to observer events on a INPUT proxy. More... | |
vtkSMRemoteObject () | |
Default constructor. More... | |
~vtkSMRemoteObject () override | |
Destructor. More... | |
void | PushState (vtkSMMessage *msg) |
Subclasses can call this method to send a message to its state object on the server processes specified. More... | |
bool | PullState (vtkSMMessage *msg) |
Subclasses can call this method to pull the state from the state-object on the server processes specified. More... | |
void | SetGlobalID (vtkTypeUInt32 guid) |
Set the GlobalUniqueId. More... | |
vtkTypeUInt32 | GetFilteredLocation () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
int | SynchronizeInteractiveRenders |
vtkCommand * | Observer |
int | PropagateUpdateVTKObjects |
bool | Enabled |
vtkSMMessage * | State |
vtkTypeUInt32 | GlobalID |
vtkTypeUInt32 | Location |
bool | Prototype |
bool | ClientOnlyLocationFlag |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | vtkInternals |
When a link is created between camera A->B, whenever any property on camera A is modified, a property with the same name as the modified property (if any) on camera B is also modified to be the same as the property on the camera A. Similarly whenever camera A->UpdateVTKObjects() is called, B->UpdateVTKObjects() is also fired.
Definition at line 22 of file vtkSMCameraLink.h.
Definition at line 26 of file vtkSMCameraLink.h.
Reimplemented from vtkSMProxyLink.
On by default.
On by default.
On by default.
On by default.
For each pair, first item is the (information) property to read and the second is the property to set.
updateDir determines whether a property of the proxy is read or written. When a property of an input proxy changes, it's value is pushed to all other output proxies in the link. A proxy can be set to be both input and output by setting updateDir to INPUT | OUTPUT
interactive
indicates if the render is interactive or not.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
overrideprotectedvirtual |
Argument is the input proxy.
caller:- the input proxy. pname:- name of the property being modified.
inlineoverrideprotectedvirtual |
caller :- the input proxy. pname :- name of property that was pushed.
Definition at line 97 of file vtkSMCameraLink.h.
Definition at line 102 of file vtkSMCameraLink.h.
friend |
Definition at line 122 of file vtkSMCameraLink.h.
Definition at line 112 of file vtkSMCameraLink.h.
