class providing access to the documentation for a vtkSMProxy. More...
#include <vtkSMDocumentation.h>
const char * | GetLongHelp () |
Returns the text for long help, if any. More... | |
const char * | GetShortHelp () |
Returns the text for short help, if any. More... | |
const char * | GetDescription () |
Returns the description text, if any. More... | |
virtual void | Modified () |
static vtkSMDocumentation * | New () |
static vtkSMDocumentation * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
Protected Attributes | |
vtkPVXMLElement * | DocumentationElement |
bool | Debug |
vtkTimeStamp | MTime |
void | SetDocumentationElement (vtkPVXMLElement *) |
Get/Set the documentation XML element. More... | |
virtual vtkPVXMLElement * | GetDocumentationElement () |
vtkSMDocumentation () | |
~vtkSMDocumentation () override | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Every proxy defined in the server manager XML can have documentation associated with it. This class provides access to the various types of documentation text for every proxy.
Definition at line 21 of file vtkSMDocumentation.h.
Definition at line 25 of file vtkSMDocumentation.h.
const char* vtkSMDocumentation::GetLongHelp | ( | ) |
nullptr otherwise.
const char* vtkSMDocumentation::GetShortHelp | ( | ) |
nullptr otherwise.
const char* vtkSMDocumentation::GetDescription | ( | ) |
void vtkSMDocumentation::SetDocumentationElement | ( | vtkPVXMLElement * | ) |
Definition at line 55 of file vtkSMDocumentation.h.
