file system utilties More...
#include <vtkSMFileUtilities.h>
bool | MakeDirectory (const std::string &name, vtkTypeUInt32 location) |
Make a directory on the specified location. More... | |
bool | DeleteDirectory (const std::string &name, vtkTypeUInt32 location) |
Delete a directory on the specified location. More... | |
bool | RenameDirectory (const std::string &name, const std::string &newname, vtkTypeUInt32 location) |
Rename a directory on the specified location. More... | |
virtual void | Modified () |
static vtkSMFileUtilities * | New () |
static vtkSMFileUtilities * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMFileUtilities () | |
~vtkSMFileUtilities () override | |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMFileUtilities can be used to make various file-system related queries and updates by applications. It is intended to be used instead of the ("misc", "Directory")
proxy (or vtkSMDirectoryProxy
) since this class can better support MPI and symmetric-MPI mode of operation. It does that as follows:
Definition at line 31 of file vtkSMFileUtilities.h.
Definition at line 35 of file vtkSMFileUtilities.h.
Reimplemented from vtkSMSessionObject.
bool vtkSMFileUtilities::MakeDirectory | ( | const std::string & | name, |
vtkTypeUInt32 | location | ||
Returns true on success or if the directory already exists.
In symmetric MPI mode, this method must be called on all MPI ranks otherwise it will cause a deadlock.
bool vtkSMFileUtilities::DeleteDirectory | ( | const std::string & | name, |
Returns true on success.
bool vtkSMFileUtilities::RenameDirectory | ( | const std::string & | name, |
const std::string & | newname, | ||
