bool | MakeDirectory (const char *dir) |
| Create directory. More...
bool | DeleteDirectory (const char *dir) |
| Remove a directory. More...
bool | Rename (const char *oldname, const char *newname) |
| Rename a file or directory. More...
bool | List (const char *dir) |
| List server side directory NEVER USED IN PARAVIEW, TODO ? More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
