vtkSMProxyConfigurationWriter Class Reference
Base readers of a vtkSMProxy's vtkSMProperty's. More...
#include <vtkSMProxyConfigurationWriter.h>
Inheritance diagram for vtkSMProxyConfigurationWriter:
Collaboration diagram for vtkSMProxyConfigurationWriter:
virtual void SetFileDescription (const char *)
virtual char * GetFileDescription ()
virtual void SetFileExtension (const char *)
virtual char * GetFileExtension ()
virtual const char * GetWriterVersion ()
 Return the writer version string. More...
virtual int WriteConfiguration (ostream &os)
 Write the proxy's state to a stream, in PV state format. More...
virtual void SetProxy (vtkSMProxy *proxy)
 Set the proxy to write out. More...
virtual vtkSMProxyGetProxy ()
virtual void SetPropertyIterator (vtkSMPropertyIterator *iter)
 Set the ieterator used to traverse properties during the write. More...
virtual vtkSMPropertyIteratorGetPropertyIterator ()
 Set/Get the file name. More...
virtual char * GetFileName ()
virtual void SetFileIdentifier (const char *)
 Set/get file meta data. More...
virtual char * GetFileIdentifier ()
virtual int WriteConfiguration ()
 Write the proxy's state directly to an XML file, in PV state format. More...
virtual int WriteConfiguration (const char *fileName)
- Public Member Functions inherited from vtkSMObject
static vtkSMProxyConfigurationWriterNew ()
static vtkSMProxyConfigurationWriterSafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMProxyConfigurationWriter ()
 ~vtkSMProxyConfigurationWriter () override
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMProxyConfigurationWriter writes state for properties for a single proxy. Internally the ParaView state machinery is employed.
The notion of proxy configuration is similar to state but lighter as the proxy its domains and and its server side objects are assumed to already exist. Configuration also provides subseting mechanism so that properties may be excluded if needed.
Subsetting is achieved through a specialized iterator derived from vtkSMPropertyIterator.
See also
vtkSMProxyConfigurationReader, vtkSMPropertyIterator, vtkSMNamedPropertyIterator
This class was contribued by SciberQuest Inc.
Definition at line 36 of file vtkSMProxyConfigurationWriter.h.
Definition at line 40 of file vtkSMProxyConfigurationWriter.h.
◆ vtkSMProxyConfigurationWriter()
vtkSMProxyConfigurationWriter::vtkSMProxyConfigurationWriter ( )
◆ ~vtkSMProxyConfigurationWriter()
vtkSMProxyConfigurationWriter::~vtkSMProxyConfigurationWriter ( )
static vtkSMProxyConfigurationWriter* vtkSMProxyConfigurationWriter::New ( )
virtual const char* vtkSMProxyConfigurationWriter::GetClassName ( )
Reimplemented in vtkSMCameraConfigurationWriter.
static int vtkSMProxyConfigurationWriter::IsTypeOf ( const char *  type)
virtual int vtkSMProxyConfigurationWriter::IsA ( const char *  type)
static vtkSMProxyConfigurationWriter* vtkSMProxyConfigurationWriter::SafeDownCast ( vtkObject o)
void vtkSMProxyConfigurationWriter::PrintSelf ( ostream &  os,
◆ SetProxy()
virtual void vtkSMProxyConfigurationWriter::SetProxy ( vtkSMProxy proxy)
◆ GetProxy()
virtual vtkSMProxy* vtkSMProxyConfigurationWriter::GetProxy ( )
◆ SetPropertyIterator()
virtual void vtkSMProxyConfigurationWriter::SetPropertyIterator ( vtkSMPropertyIterator iter)
If no iterator is set then all properties are written.
◆ GetPropertyIterator()
virtual vtkSMPropertyIterator* vtkSMProxyConfigurationWriter::GetPropertyIterator ( )
◆ SetFileName()
virtual void vtkSMProxyConfigurationWriter::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkSMProxyConfigurationWriter::GetFileName ( )
◆ SetFileIdentifier()
virtual void vtkSMProxyConfigurationWriter::SetFileIdentifier ( const char *  )
◆ GetFileIdentifier()
virtual char* vtkSMProxyConfigurationWriter::GetFileIdentifier ( )
◆ SetFileDescription()
virtual void vtkSMProxyConfigurationWriter::SetFileDescription ( const char *  )
◆ GetFileDescription()
virtual char* vtkSMProxyConfigurationWriter::GetFileDescription ( )
◆ SetFileExtension()
virtual void vtkSMProxyConfigurationWriter::SetFileExtension ( const char *  )
◆ GetFileExtension()
virtual char* vtkSMProxyConfigurationWriter::GetFileExtension ( )
◆ GetWriterVersion()
virtual const char* vtkSMProxyConfigurationWriter::GetWriterVersion ( )
inlinevirtual
Definition at line 85 of file vtkSMProxyConfigurationWriter.h.
◆ WriteConfiguration() [1/3]
virtual int vtkSMProxyConfigurationWriter::WriteConfiguration ( )
◆ WriteConfiguration() [2/3]
virtual int vtkSMProxyConfigurationWriter::WriteConfiguration ( const char *  fileName)
◆ WriteConfiguration() [3/3]
virtual int vtkSMProxyConfigurationWriter::WriteConfiguration ( ostream &  os)
