Base readers of a vtkSMProxy's vtkSMProperty's. More...
#include <vtkSMProxyConfigurationReader.h>
virtual void | SetFileDescription (const char *) |
virtual char * | GetFileDescription () |
virtual void | SetFileExtension (const char *) |
virtual char * | GetFileExtension () |
virtual const char * | GetReaderVersion () |
Return the reader version. More... | |
virtual bool | CanReadVersion (const char *version) |
Return true if the reader can read the specified version. More... | |
virtual int | ReadConfiguration (vtkPVXMLElement *xmlStream) |
Read the configuration from the stream. More... | |
virtual void | SetFileName (const char *) |
Set/Get the file name. More... | |
virtual char * | GetFileName () |
virtual void | SetProxy (vtkSMProxy *proxy) |
Set the proxy to write out. More... | |
virtual vtkSMProxy * | GetProxy () |
virtual void | SetFileIdentifier (const char *) |
Set/get file meta data. More... | |
virtual char * | GetFileIdentifier () |
virtual void | SetValidateProxyType (int) |
Turns on/off proxy type validation. More... | |
virtual int | GetValidateProxyType () |
virtual int | ReadConfiguration () |
Read the configuration from the file. More... | |
virtual int | ReadConfiguration (const char *filename) |
virtual void | Modified () |
static vtkSMProxyConfigurationReader * | New () |
static vtkSMProxyConfigurationReader * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMProxyConfigurationReader () | |
~vtkSMProxyConfigurationReader () override | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMProxyConfigurationReader reads state for properties for a single proxy. Internally the ParaView state machinery is employed.
The notion of proxy configuration is similar to state but lighter as the proxy its domains and and its server side objects are assumed to already exist. Configuration also provides subseting mechanism so that properties may be excluded if needed.
The subsetting mechanism is implemented in the writer, the reader simply reads which ever properties are found.
Definition at line 36 of file vtkSMProxyConfigurationReader.h.
Definition at line 40 of file vtkSMProxyConfigurationReader.h.
Reimplemented in vtkSMCameraConfigurationReader.
If on then the proxy's type is compared with that found in the configuration file. The read fails if they do not match. The feature is on by default.
inlinevirtual |
Definition at line 87 of file vtkSMProxyConfigurationReader.h.
UpdateVTKObjects is intentionally not called so that caller may have full control as to when the push from client to server takes place.
PV state machinery is employed.
