vtkSMViewExportHelper Class Reference
helper class to export views. More...
#include <vtkSMViewExportHelper.h>
Inheritance diagram for vtkSMViewExportHelper:
Collaboration diagram for vtkSMViewExportHelper:
virtual std::string GetSupportedFileTypes (vtkSMViewProxy *view)
 Returns a formatted string with all supported file types for the given view. More...
virtual vtkSMExporterProxyCreateExporter (const char *filename, vtkSMViewProxy *)
 Exports the view to the given output file. More...
- Public Member Functions inherited from vtkSMObject
static vtkSMViewExportHelperNew ()
static vtkSMViewExportHelperSafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMViewExportHelper ()
 ~vtkSMViewExportHelper () override
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMViewExportHelper is a helper class to aid in exporting views. You can create instances of this helper on-demand to query available exporters and create and exporter proxy (in same spirit as vtkSMWriterFactory, except that there's no globally existing instance).
Definition at line 24 of file vtkSMViewExportHelper.h.
Definition at line 28 of file vtkSMViewExportHelper.h.
◆ vtkSMViewExportHelper()
vtkSMViewExportHelper::vtkSMViewExportHelper ( )
◆ ~vtkSMViewExportHelper()
vtkSMViewExportHelper::~vtkSMViewExportHelper ( )
static vtkSMViewExportHelper* vtkSMViewExportHelper::New ( )
virtual const char* vtkSMViewExportHelper::GetClassName ( )
static int vtkSMViewExportHelper::IsTypeOf ( const char *  type)
virtual int vtkSMViewExportHelper::IsA ( const char *  type)
static vtkSMViewExportHelper* vtkSMViewExportHelper::SafeDownCast ( vtkObject o)
void vtkSMViewExportHelper::PrintSelf ( ostream &  os,
◆ GetSupportedFileTypes()
virtual std::string vtkSMViewExportHelper::GetSupportedFileTypes ( vtkSMViewProxy view)
An example returned string would look like:
* "PVD Files (*.pvd);;VTK Files (*.vtk)"
◆ CreateExporter()
virtual vtkSMExporterProxy* vtkSMViewExportHelper::CreateExporter ( const char *  filename,
vtkSMViewProxy
Returns a new exporter instance (or nullptr). Caller must release the returned object explicitly.
