is a factory or creating a writer based on the data type information from the output port. More...
#include <vtkSMWriterFactory.h>
| void | Initialize () |
| Cleanup all registered prototypes. More... | |
| void | RegisterPrototype (const char *xmlgroup, const char *xmlname) |
| Register a prototype. More... | |
| bool | CanWrite (vtkSMSourceProxy *, unsigned int outputport) |
| Returns true if the data from the output port can be written at all. More... | |
| vtkSMProxy * | CreateWriter (const char *filename, vtkSMSourceProxy *, unsigned int outputport=0, bool proxyname=false) |
| Create a new writer proxy to write the data from the specified output port to the file specified, if possible. More... | |
| vtkSMProxy * | CreateWriter (const char *filename, vtkSMSourceProxy *, unsigned int outputport, const char *writerProxyName) |
| After using GetCorrectWriterName, use this method to create the writer proxy. More... | |
| std::string | GetCorrectWriterName (const char *filename, vtkSMSourceProxy *source, unsigned int outputport, const char *writerProxyName) |
| Given a filename, source and output port, and a writer proxy name, return the correct writer proxy name to use. More... | |
| const char * | GetSupportedFileTypes (vtkSMSourceProxy *source, unsigned int outputport) |
| Returns a formatted string with all supported file types. More... | |
| const char * | GetSupportedFileTypes (vtkSMSourceProxy *source) |
| unsigned int | GetNumberOfRegisteredPrototypes () |
| void | UpdateAvailableWriters () |
| Every time a new proxy definition is added we check to see if it is a writer and then we add it to the list of available writers. More... | |
| vtkStringList * | GetPossibleWriters (vtkSMSourceProxy *source, unsigned int outputport) |
| A variation on GetSupportedFileTypes that obtains a list of prototype proxy names. More... | |
| const char * | GetSupportedWriterProxies (vtkSMSourceProxy *source, unsigned int outputport) |
| void | AddGroup (const char *groupName) |
| Add/remove a group name to look for writers in. More... | |
| void | RemoveGroup (const char *groupName) |
| void | GetGroups (vtkStringList *groups) |
| static vtkSMWriterFactory * | New () |
| static vtkSMWriterFactory * | SafeDownCast (vtkObject *o) |
| static void | AddWriterToWhitelist (const char *writerxmlgroup, const char *writerxmlname) |
| This function is for ParaView based applications that only wish to expose a subset of the writers. More... | |
| vtkSMWriterFactory () | |
| ~vtkSMWriterFactory () override | |
| vtkSMObject () | |
vtkSMWriterFactory is a factory for creating a writer to write the data provided at an output port. This is done whenever a new proxy definition is added in the writers group.
Alternatively, one can register prototypes using RegisterPrototype API. The proxy definitions for the writer proxies must provide hints that indicate the file extension and description for the writer.
Once the factory has been configured, the API to create writers, get available writers etc. can be used.
Definition at line 33 of file vtkSMWriterFactory.h.
Definition at line 37 of file vtkSMWriterFactory.h.
| void vtkSMWriterFactory::Initialize | ( | ) |
| bool vtkSMWriterFactory::CanWrite | ( | vtkSMSourceProxy * | , |
| unsigned int | outputport | ||
| vtkSMProxy* vtkSMWriterFactory::CreateWriter | ( | const char * | filename, |
| vtkSMSourceProxy * | , | ||
| unsigned int | outputport = 0, |
| bool | proxyname = false |
As internally UpdatePipeline() will be called on the source proxy, in order to prevent a double pipeline execution when you want to write a given timestep, you should call updatePipeline( time ) before the CreateWriter call. The proxybyname flag tells the factory to use the proxy name rather than a filename.extension to lookup the right proxy.
| unsigned int | outputport, | ||
| const char * | writerProxyName | ||
| std::string vtkSMWriterFactory::GetCorrectWriterName | ( | const char * | filename, |
| vtkSMSourceProxy * | source, | ||
This is needed because a user may either select the writer specifically or expect the correct writer to be chosen based on the filename extension.
| const char* vtkSMWriterFactory::GetSupportedFileTypes | ( | vtkSMSourceProxy * | source, |
An example returned string would look like:
* "PVD Files (*.pvd);;VTK Files (*.vtk)" *
Definition at line 91 of file vtkSMWriterFactory.h.
| vtkStringList* vtkSMWriterFactory::GetPossibleWriters | ( | vtkSMSourceProxy * | source, |
| const char* vtkSMWriterFactory::GetSupportedWriterProxies | ( | vtkSMSourceProxy * | source, |
| unsigned int vtkSMWriterFactory::GetNumberOfRegisteredPrototypes | ( | ) |
| void vtkSMWriterFactory::UpdateAvailableWriters | ( | ) |
| void vtkSMWriterFactory::AddGroup | ( | const char * | groupName | ) |
By default "writers" is included.
| void vtkSMWriterFactory::RemoveGroup | ( | const char * | groupName | ) |
| void vtkSMWriterFactory::GetGroups | ( | vtkStringList * | groups | ) |
If this function is never called, the reader factory will expose all the writers as it has in the past. However, if any writers are specified by passing their group name and reader name to this function, then only those writers will be available in any reader factories created by the application. This is intended to be called at the beginning of the application's execution before any sessions are created.
1.8.13 on Sun Dec 14 2025
