vtkSelectionDeliveryFilter Class Reference
vtkSelectionDeliveryFilter is a filter that can deliver vtkSelection from data-server nodes to the client. More...
#include <vtkSelectionDeliveryFilter.h>
Inheritance diagram for vtkSelectionDeliveryFilter:
Collaboration diagram for vtkSelectionDeliveryFilter:
typedef vtkSelectionAlgorithm Superclass
- Public Types inherited from vtkSelectionAlgorithm
enum  DesiredOutputPrecision
- Public Member Functions inherited from vtkSelectionAlgorithm
vtkSelectionAlgorithmNewInstance () const
vtkSelectionGetOutput ()
vtkSelectionGetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkSelectionDeliveryFilterNew ()
static vtkSelectionDeliveryFilterSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSelectionAlgorithm
static vtkSelectionAlgorithmNew ()
static vtkSelectionAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSelectionDeliveryFilter ()
 ~vtkSelectionDeliveryFilter () override
- Protected Member Functions inherited from vtkSelectionAlgorithm
 vtkSelectionAlgorithm ()
 ~vtkSelectionAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkReductionFilterReductionFilter
vtkClientServerMoveDataDeliveryFilter
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This should not be instantiated on the pure-render-server nodes to avoid odd side effects (We can fix this later if the need arises).
Definition at line 21 of file vtkSelectionDeliveryFilter.h.
Definition at line 26 of file vtkSelectionDeliveryFilter.h.
◆ vtkSelectionDeliveryFilter()
vtkSelectionDeliveryFilter::vtkSelectionDeliveryFilter ( )
◆ ~vtkSelectionDeliveryFilter()
vtkSelectionDeliveryFilter::~vtkSelectionDeliveryFilter ( )
static vtkSelectionDeliveryFilter* vtkSelectionDeliveryFilter::New ( )
virtual const char* vtkSelectionDeliveryFilter::GetClassName ( )
static int vtkSelectionDeliveryFilter::IsTypeOf ( const char *  type)
virtual int vtkSelectionDeliveryFilter::IsA ( const char *  type)
Reimplemented from vtkSelectionAlgorithm.
static vtkSelectionDeliveryFilter* vtkSelectionDeliveryFilter::SafeDownCast ( vtkObject o)
void vtkSelectionDeliveryFilter::PrintSelf ( ostream &  os,
◆ FillInputPortInformation()
int vtkSelectionDeliveryFilter::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ RequestData()
int vtkSelectionDeliveryFilter::RequestData ( vtkInformation request,
vtkInformationVector outputVector
◆ ReductionFilter
vtkReductionFilter* vtkSelectionDeliveryFilter::ReductionFilter
Definition at line 37 of file vtkSelectionDeliveryFilter.h.
◆ DeliveryFilter
vtkClientServerMoveData* vtkSelectionDeliveryFilter::DeliveryFilter
Definition at line 38 of file vtkSelectionDeliveryFilter.h.
