int | ProcessViewRequest (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo) override |
| vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
void | SetUseLICForLOD (bool val) |
void | SetEnable (bool val) |
void | SetNumberOfSteps (int val) |
void | SetStepSize (double val) |
void | SetNormalizeVectors (int val) |
void | SetEnhancedLIC (int val) |
void | SetEnhanceContrast (int val) |
void | SetLowLICContrastEnhancementFactor (double val) |
void | SetHighLICContrastEnhancementFactor (double val) |
void | SetLowColorContrastEnhancementFactor (double val) |
void | SetHighColorContrastEnhancementFactor (double val) |
void | SetAntiAlias (int val) |
void | SetColorMode (int val) |
void | SetMapModeBias (double val) |
void | SetLICIntensity (double val) |
void | SetMaskOnSurface (int val) |
void | SetMaskThreshold (double val) |
void | SetMaskColor (double *val) |
void | SetMaskColor (double r, double g, double b) |
void | SetMaskIntensity (double val) |
void | SetGenerateNoiseTexture (int val) |
void | SetNoiseType (int val) |
void | SetNoiseTextureSize (int val) |
void | SetNoiseGrainSize (int val) |
void | SetMinNoiseValue (double val) |
void | SetMaxNoiseValue (double val) |
void | SetNumberOfNoiseLevels (int val) |
void | SetImpulseNoiseProbability (double val) |
void | SetImpulseNoiseBackgroundValue (double val) |
void | SetNoiseGeneratorSeed (int val) |
void | SetCompositeStrategy (int val) |
void | WriteTimerLog (const char *fileName) |
void | SelectInputVectors (int, int, int, int attributeMode, const char *name) |
void | SetVisibility (bool val) override |
| Get/Set the visibility for this representation. More...
void | SetBackfaceAmbientColor (double r, double g, double b) |
void | SetBackfaceDiffuseColor (double r, double g, double b) |
void | SetBackfaceOpacity (double val) |
virtual void | SetBackfaceRepresentation (int) |
| Set the backface representation. More...
virtual int | GetBackfaceRepresentation () |
virtual void | SetSuppressLOD (bool suppress) |
| Enable/Disable LOD;. More...
virtual void | SetRepresentation (const char *) |
| Overload to set representation type using string. More...
vtkDataObject * | GetRenderedDataObject (int port) override |
| Returns the data object that is rendered from the given input port. More...
virtual void | SetNormalArray (const char *val) |
| Set the normal array used for smooth shading. More...
virtual void | SetTCoordArray (const char *val) |
| Set the texture coordinates array used for texture mapping. More...
virtual void | SetTangentArray (const char *val) |
| Set the tangent coordinates array used for normal mapping. More...
virtual void | SetUseOutline (int) |
void | SetTriangulate (int) |
void | SetNonlinearSubdivisionLevel (int) |
void | SetMatchBoundariesIgnoringCellOrder (int) |
virtual void | SetGenerateFeatureEdges (bool) |
void | SetComputePointNormals (bool) |
void | SetSplitting (bool) |
void | SetFeatureAngle (double) |
virtual void | SetAmbientColor (double r, double g, double b) |
virtual void | SetColor (double r, double g, double b) |
virtual void | SetDiffuseColor (double r, double g, double b) |
virtual void | SetLighting (bool lighting) |
virtual void | SetEdgeColor (double r, double g, double b) |
virtual void | SetInteractiveSelectionColor (double r, double g, double b) |
virtual void | SetInterpolation (int val) |
virtual void | SetLineWidth (double val) |
virtual void | SetOpacity (double val) |
virtual void | SetEdgeOpacity (double val) |
virtual void | SetPointSize (double val) |
virtual void | SetSpecularColor (double r, double g, double b) |
virtual void | SetSpecularPower (double val) |
virtual void | SetLuminosity (double val) |
virtual void | SetRenderPointsAsSpheres (bool) |
virtual void | SetRenderLinesAsTubes (bool) |
virtual void | SetRoughness (double val) |
virtual void | SetMetallic (double val) |
virtual void | SetEdgeTint (double r, double g, double b) |
virtual void | SetAnisotropy (double val) |
virtual void | SetAnisotropyRotation (double val) |
virtual void | SetBaseIOR (double val) |
virtual void | SetCoatIOR (double val) |
virtual void | SetCoatStrength (double val) |
virtual void | SetCoatRoughness (double val) |
virtual void | SetCoatNormalScale (double val) |
virtual void | SetCoatColor (double r, double g, double b) |
virtual void | SetBaseColorTexture (vtkTexture *tex) |
virtual void | SetMaterialTexture (vtkTexture *tex) |
virtual void | SetAnisotropyTexture (vtkTexture *tex) |
virtual void | SetNormalTexture (vtkTexture *tex) |
virtual void | SetCoatNormalTexture (vtkTexture *tex) |
virtual void | SetEmissiveTexture (vtkTexture *tex) |
virtual void | SetNormalScale (double val) |
virtual void | SetOcclusionStrength (double val) |
virtual void | SetEmissiveFactor (double rval, double gval, double bval) |
virtual void | SetShowTexturesOnBackface (bool) |
virtual void | SetOrientation (double, double, double) |
virtual void | SetOrigin (double, double, double) |
virtual void | SetPickable (int val) |
virtual void | SetPosition (double, double, double) |
virtual void | SetScale (double, double, double) |
virtual void | SetTexture (vtkTexture *) |
virtual void | SetUserTransform (const double[16]) |
virtual void | SetFlipTextures (bool) |
virtual void | SetCoordinateSystem (int) |
virtual void | SetTextureTransform (vtkTransform *) |
virtual vtkTransform * | GetTextureTransform () |
virtual void | SetRepeatTextures (bool) |
virtual bool | GetRepeatTextures () |
virtual void | SetInterpolateTextures (bool) |
virtual bool | GetInterpolateTextures () |
virtual void | SetUseMipmapTextures (bool) |
virtual bool | GetUseMipmapTextures () |
virtual void | SetInterpolateScalarsBeforeMapping (int val) |
virtual void | SetLookupTable (vtkScalarsToColors *val) |
virtual void | SetColorMissingArraysWithNanColor (bool val) |
virtual void | SetSeamlessU (bool) |
virtual void | SetSeamlessV (bool) |
virtual void | SetSelection (vtkSelection *selection) |
| Sets the selection used by the mapper. More...
vtkPVLODActor * | GetActor () |
| Provides access to the actor used by this representation. More...
const char * | GetColorArrayName () |
| Convenience method to get the array name used to scalar color with. More...
virtual void | SetMaterial (const char *) |
| For OSPRay, choose from among available materials. More...
virtual void | SetShaderReplacements (const char *) |
| Specify shader replacements using a Json string. More...
void | SetArrayIdNames (const char *pointArray, const char *cellArray) override |
| Specify the array names used for the selection. More...
void | SetBlockColorsDistinctValues (int distinctValues) |
| Determines the number of distinct values in vtkBlockColors See also vtkPVGeometryFilter. More...
int | GetBlockColorsDistinctValues () |
virtual void | DisableLightingOn () |
| Disables the lighting on the object. More...
virtual void | DisableLightingOff () |
virtual void | SetDisableLighting (bool) |
virtual bool | GetDisableLighting () |
virtual void | SetAmbient (double) |
| Set the lighting properties of the object. More...
virtual void | SetDiffuse (double) |
virtual void | SetSpecular (double) |
virtual double | GetAmbient () |
virtual double | GetDiffuse () |
virtual double | GetSpecular () |
void | SetCoordinateShiftScaleMethod (int val) |
| Set the shift scale method for the point coordinates see vtkOpenGLVertexBufferObject.h for more information. More...
int | GetCoordinateShiftScaleMethod () |
virtual void | SetRepresentation (int) |
| Set the representation type. More...
virtual int | GetRepresentation () |
virtual void | SetRequestGhostCellsIfNeeded (bool) |
| Representations that use geometry representation as the internal representation should turn this flag off so that we don't end up requesting ghost cells twice. More...
virtual bool | GetRequestGhostCellsIfNeeded () |
virtual void | RequestGhostCellsIfNeededOn () |
virtual void | RequestGhostCellsIfNeededOff () |
virtual void | SetMapScalars (int val) |
| Sets if scalars are mapped through a color-map or are used directly as colors. More...
virtual void | SetStatic (int val) |
virtual void | SetActiveAssembly (const char *) |
| Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More...
virtual char * | GetActiveAssembly () |
void | AddBlockSelector (const char *selector) |
| Update list of selectors that determine the selected blocks. More...
void | RemoveAllBlockSelectors () |
void | SetBlockColor (const char *selector, double r, double g, double b) |
| Set the color for a single block. More...
void | RemoveAllBlockColors () |
void | SetBlockOpacity (const char *selector, double opacity) |
| Set the opacity for a single block. More...
void | RemoveAllBlockOpacities () |
void | SetBlockInterpolateScalarsBeforeMapping (const char *selector, bool interpolate) |
| Set if to interpolate scalars before mapping for a single block. More...
void | RemoveAllBlockInterpolateScalarsBeforeMappings () |
void | SetBlockMapScalars (const char *selector, int val) |
| Set the block to map scalars for a single block. More...
void | RemoveAllBlockMapScalars () |
void | SetBlockArrayName (const char *selector, int assoc, const char *arrayName) |
| Set the color array for a single block. More...
void | RemoveAllBlockArrayNames () |
void | SetBlockLookupTable (vtkScalarsToColors *lut) |
| Set the look up table for a single block. More...
void | RemoveAllBlockLookupTables () |
virtual void | SetEnableScaling (int v) |
| For OSPRay controls sizing of implicit spheres (points) and cylinders (lines) More...
virtual void | SetScalingArrayName (const char *) |
virtual void | SetScalingFunction (vtkPiecewiseFunction *pwf) |
virtual void | SetUseDataPartitions (bool) |
| Specify whether or not to redistribute the data. More...
virtual bool | GetUseDataPartitions () |
virtual void | SetUseShaderReplacements (bool) |
| Specify whether or not to shader replacements string must be used. More...
virtual bool | GetUseShaderReplacements () |
void | SetPlaceHolderDataType (int datatype) |
| Set/Get the placeholder data type. More...
virtual int | GetPlaceHolderDataType () |
virtual void | MarkModified () |
| This is one of the most important functions. More...
virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
unsigned int | GetUniqueIdentifier () |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More...
virtual bool | GetVisibility () |
virtual vtkDataObject * | GetRenderedDataObject (int vtkNotUsed(port)) |
double | GetCacheKey () const |
| Returns the cache-key the representation is currently using. More...
vtkAlgorithmOutput * | GetInternalOutputPort () override |
| Retrieves an output port for the input data object at the specified port and connection index. More...
vtkAlgorithmOutput * | GetInternalOutputPort (int port) override |
vtkAlgorithmOutput * | GetInternalOutputPort (int port, int conn) override |
vtkView * | GetView () const |
| Provides access to the view. More...
vtkMTimeType | GetPipelineDataTime () |
| Returns the timestamp when RequestData was executed on the representation. More...
bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More...
virtual void | SetArrayIdNames (const char *vtkNotUsed(pointArray), const char *vtkNotUsed(cellArray)) |
virtual void | SetUpdateTime (double time) |
| Set the update time. More...
virtual double | GetUpdateTime () |
virtual bool | GetUpdateTimeValid () |
| Get whether the UpdateTime is valid. More...
void | ResetUpdateTime () |
virtual void | SetForcedCacheKey (double val) |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More...
virtual void | SetForceUseCache (bool val) |
virtual double | GetForcedCacheKey () |
virtual bool | GetForceUseCache () |
bool | AddToView (vtkView *view) override |
| Making these methods public. More...
bool | RemoveFromView (vtkView *view) override |
virtual void | SetLogName (const std::string &name) |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More...
const std::string & | GetLogName () const |
virtual bool | GetHasTemporalPipeline () |
| This flag indicates if the representation is for a temporal pipeline. More...
virtual void | SetHasTemporalPipeline (bool) |
void | SetInputConnection (int port, vtkAlgorithmOutput *input) override |
| Overridden to ensure that MarkModified is called. More...
void | AddInputConnection (int port, vtkAlgorithmOutput *input) override |
vtkDataRepresentation * | NewInstance () const |
virtual void | ApplyViewTheme (vtkViewTheme *vtkNotUsed(theme)) |
virtual vtkSelection * | ConvertSelection (vtkView *view, vtkSelection *selection) |
vtkAlgorithmOutput * | GetInputConnection (int port=0, int index=0) |
vtkAnnotationLink * | GetAnnotationLink () |
void | SetAnnotationLink (vtkAnnotationLink *link) |
void | Select (vtkView *view, vtkSelection *selection) |
void | Select (vtkView *view, vtkSelection *selection, bool extend) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations, bool extend) |
virtual void | SetSelectable (bool) |
virtual bool | GetSelectable () |
virtual void | SelectableOn () |
virtual void | SelectableOff () |
void | UpdateSelection (vtkSelection *selection) |
void | UpdateSelection (vtkSelection *selection, bool extend) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations, bool extend) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port, int conn) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port, int conn) |
virtual void | SetSelectionType (int) |
virtual int | GetSelectionType () |
virtual void | SetSelectionArrayNames (vtkStringArray *names) |
virtual vtkStringArray * | GetSelectionArrayNames () |
virtual void | SetSelectionArrayName (const char *name) |
virtual const char * | GetSelectionArrayName () |
vtkPassInputTypeAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataOutput () |
vtkStructuredPoints * | GetStructuredPointsOutput () |
vtkImageData * | GetImageDataOutput () |
vtkStructuredGrid * | GetStructuredGridOutput () |
vtkUnstructuredGrid * | GetUnstructuredGridOutput () |
vtkRectilinearGrid * | GetRectilinearGridOutput () |
vtkTable * | GetTableOutput () |
vtkGraph * | GetGraphOutput () |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkSurfaceLICRepresentation () |
| ~vtkSurfaceLICRepresentation () override |
void | UpdateColoringParameters () override |
| Passes on parameters to vtkProperty and vtkMapper. More...
| vtkGeometryRepresentationWithFaces () |
| ~vtkGeometryRepresentationWithFaces () override |
void | SetupDefaults () override |
| This method is called in the constructor. More...
| Adds the representation to the view. More...
| Removes the representation to the view. More...
bool | NeedsOrderedCompositing () override |
| Returns true if this representation has translucent geometry. More...
| vtkGeometryRepresentation () |
| ~vtkGeometryRepresentation () override |
int | FillInputPortInformation (int port, vtkInformation *info) override |
| Fill input port information. More...
int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
int | RequestUpdateExtent (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| Overridden to request correct ghost-level to avoid internal surfaces. More...
virtual vtkPVLODActor * | GetRenderedProp () |
| Used in ConvertSelection to locate the prop used for actual rendering. More...
void | HandleGeometryRepresentationProgress (vtkObject *caller, unsigned long, void *) |
void | PopulateBlockAttributes (vtkCompositeDataDisplayAttributes *attrs, vtkDataObject *outputData) |
| Block attributes in a mapper are referenced to each block through DataObject pointers. More...
void | ComputeVisibleDataBounds () |
| Computes the bounds of the visible data based on the block visibilities in the composite data attributes of the mapper. More...
void | UpdateShaderReplacements () |
| Update the mapper with the shader replacement strings if feature is enabled. More...
virtual void | SetPointArrayToProcess (int p, const char *val) |
| Used by SetNormalArray, SetTCoordArray and SetTangentArray. More...
void | UpdateGeneralTextureTransform () |
| This is called whenever the texture transformation matrix changes. More...
| vtkPVDataRepresentation () |
| ~vtkPVDataRepresentation () override |
vtkExecutive * | CreateDefaultExecutive () override |
| Create a default executive. More...
| Overridden to invoke vtkCommand::UpdateDataEvent. More...
int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkDataRepresentation () |
| ~vtkDataRepresentation () |
virtual void | ProcessEvents (vtkObject *caller, unsigned long eventId, void *callData) |
virtual bool | AddToView (vtkView *vtkNotUsed(view)) |
virtual bool | RemoveFromView (vtkView *vtkNotUsed(view)) |
virtual vtkAnnotationLayers * | ConvertAnnotations (vtkView *view, vtkAnnotationLayers *annotations) |
vtkTrivialProducer * | GetInternalInput (int port, int conn) |
void | SetInternalInput (int port, int conn, vtkTrivialProducer *producer) |
virtual void | SetAnnotationLinkInternal (vtkAnnotationLink *link) |
| vtkPassInputTypeAlgorithm () |
| ~vtkPassInputTypeAlgorithm () |
virtual int | RequestUpdateTimeDependentInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual int | RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
