3 #ifndef pqProxyCategory_h 4 #define pqProxyCategory_h 6 #include "pqApplicationComponentsModule.h" 63 typedef QObject Superclass;
92 bool parseXMLHintsTag(
93 const QString& proxyGroup,
const QString& proxyName,
vtkPVXMLElement* hints);
101 void writeSettings(
const QString& resourceTag);
105 void loadSettings(
126 bool hasProxy(
const QString& name);
131 pqProxyInfo* findProxy(
const QString& name,
bool recursive =
false);
133 QList<pqProxyInfo*> getRootProxies();
135 QList<pqProxyInfo*> getProxiesRecursive();
137 QStringList getOrderedRootProxiesNames();
147 QMap<QString, pqProxyCategory*> getSubCategories();
149 QMap<QString, pqProxyCategory*> getSubCategoriesRecursive();
151 QList<pqProxyCategory*> getCategoriesAlphabetically();
153 QString makeUniqueCategoryName(
155 QString makeUniqueCategoryLabel(
const QString& label);
165 void removeCategory(
169 void removeProxy(
177 bool hasProxiesRecursive();
185 QString
name() {
return this->Name; }
197 void rename(
201 void updateLabel(
const QString& label =
203 void setShowInToolbar(
bool show);
215 void cleanDeletedProxy(QObject* deleted);
231 bool PreserveOrder =
false;
232 bool ShowInToolbar =
false;
235 QMap<QString, pqProxyCategory*> SubCategories;
236 QStringList OrderedProxies;
QMap< QString, pqProxyInfo * > pqProxyInfoMap
map a proxy name to its pqProxyInfo
pqProxyCategory * parentCategory()
Return parent category.
QMap< QString, pqProxyCategory * > pqCategoryMap
map a category name to its pqProxyCategory
Proxy meta data structure for the User Interface.
QString name()
Return category name.
bool showInToolbar()
Return true if a toolbar should be created.
bool preserveOrder()
Return true if read order should be used in display.
void convertToXML(vtkPVXMLElement *root)
Add Proxies and SubCategories XML declaration to root element.
The pqProxyCategory class reads and writes XML that describes the proxies organisation into categorie...
