struct | vtkClientServerInterpreterErrorCallbackInfo |
A pointer to this struct is sent as call data when an ErrorEvent is invoked by the interpreter. More... | |
class | vtkClientServerInterpreter |
Run-time VTK interpreter. More... | |
struct | vtkClientServerInterpreter::NewCallbackInfo |
The callback data structure passed to observers looking for VTK object creation and deletion events. More... | |
Typedefs | |
typedef int(* | vtkClientServerCommandFunction) (vtkClientServerInterpreter *, vtkObjectBase *ptr, const char *method, const vtkClientServerStream &msg, vtkClientServerStream &result, void *ctx) |
The type of a command function. More... | |
typedef vtkObjectBase *(* | vtkClientServerNewInstanceFunction) (void *ctx) |
The type of a new-instance function. More... | |
typedef void(* | vtkContextFreeFunction) (void *ctx) |
typedef int(* vtkClientServerCommandFunction) (vtkClientServerInterpreter *, vtkObjectBase *ptr, const char *method, const vtkClientServerStream &msg, vtkClientServerStream &result, void *ctx) |
One such function is generated per class wrapped. It knows how to call the methods for that class at run-time.
Definition at line 28 of file vtkClientServerInterpreter.h.
typedef vtkObjectBase*(* vtkClientServerNewInstanceFunction) (void *ctx) |
Definition at line 34 of file vtkClientServerInterpreter.h.
typedef void(* vtkContextFreeFunction) (void *ctx) |
Definition at line 36 of file vtkClientServerInterpreter.h.
